The fitting that screws into the fuel filter.
Postby RayD » Mon 18.02.2008, 23:10
See Fuel Filter Renewal (2)
Let us know if it requires any alterations.
Ray
RayD
Postby GeoffSmith » Mon 18.02.2008, 23:19
dapinky wrote:.....if i just posted the measurements, people like you would just fish one out of your big box in the garage.......
......whilst it would fit, and do the job for now, i personally would want to know that the 'o' ring was made of a suitable material to cope with petrol without rotting or bursting under pressure.
Many 'rubber' o rings are not compatable with petrol and surely, for the sake of 55p each, it's worth going for a proper one.
Do you really want your passenger compartment to be filled with petrol vapour/fumes/liquid under high pressure - passing through the fusebox and battery compartment on the way????????????
In reverse order:
NO!
That's why I bought nitrile ones! :twisted:
Me too.
They're in the loft, not the garage. :-D
Postby dapinky » Mon 18.02.2008, 23:30
Firstly,
Thanks Ray - thats handsome, mate!
Secondly,
Geoff, I said people LIKE you - obviously NOT YOU :roll: I knew you'd have the proper kit :oops:
Sorry,
Bottom line is that I had enough thinking to do without worying about sticking callipers on the ring.
I can let you have a knackered fitting, with a squashed 'o' ring, and an old filter if you want to see what will fit?
Re: The fitting that screws into the fuel filter.
Postby Simon_P » Sat 12.11.2016, 20:20
Does anyone know where I can get this fitting from? The thread pitch is 1.5 mm
The 'O'ing number EDP9976 is good and is supplied by mini specialists.
Postby Brit-Car-Nut » Sat 12.11.2016, 23:38
Easy in the US, but I don't know UK. Try searching "gm fuel filter line repair"
Dorman # 800-153 or 800-170 are 3/8" repair lines with 16mm male fittings.
Probably available on eBay or Amazon if nowhere else.
Postby muley » Sun 13.11.2016, 09:11
Having replaced a standard filter - using Dave's guide and the Wiki, the next time I do it I expect I'll start over with something like this
https://www.inlinefilters.co.uk/Filters ... /FBW-BF794
Lots of other ideas on their website.. filter hosetails etc etc
Postby Brit-Car-Nut » Sun 13.11.2016, 15:10
Kind of hard to connect the nylon line to that kind of filter and using a fabric hose over the nylon line requires using a metal insert to prevent the line from collapsing.
Dorman also makes barbed adapters for the nylon lines that make the transition to metal lines easy and safe.
Postby simonbuk » Fri 13.03.2026, 21:05
Wish I found (searched for) this thread earlier :? !!
Some things just seem daft !
Yes I had to cut one of the hard pipes off to untwist the fuel filter off. I was wondering how to get the hard pipe back on but maybe that ain't gonna happen !!
I did put some new rubber o rings on but sounds like that ain't gonna work either :oops: .
:banghead: :bonk:
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby simonbuk » Sat 21.03.2026, 14:42
Received my new O rings from SJs yesterday so the filter is now back on with a new bit of pipe.
Let's hope it is a proper petrol resistant type and not just a normal one !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
