simonbuk wrote:According to the literature I have with the car the last couple of changes was Mobil 1 10W 60.
We have just put a slightly thicker oil going to 10W 40.
lotusflasherman wrote:simonbuk wrote:According to the literature I have with the car the last couple of changes was Mobil 1 10W 60.
huh??? 10W 40 oil will be thinner when hot, not thicker.
Both behave as SAE10 when cold so will appear the same out of the can, but when hot (at 100°C) the Mobil will behave as SAE 60 so will remain 'thicker' than the SAE 40. (Higher the number, the thicker it is.)
its worth changing the oil for a 10w 60lotusflasherman wrote:So will be there in neutral with no engine load of any significance.
lotusflasherman wrote:How many miles has the car done and how old is the oil
HJ2 wrote:Since the noise is constant...
Are you sure that you don't have a noisy CAS assembly? (worn bearings)
simonbuk wrote:HJ2 wrote:Since the noise is constant...
How can I check for this ?
