tb10 wrote:Hi Dave,
What I get is the same result as when a rev limiter kicks in so the car will bounce off the limit determined by the turbo 'trying' to boost. It occurs just before the turbo kicks in and makes a raspy noise and won't accelerate. if you don't use the boost then the car drives fine, albeit, in a pedestrian way (for the M100!).
As sated above the next day when the car is driven it is fine.
It usually happens after the car hasn't been used for a few weeks.
regards
Kathryn wrote:That's reassuring to know Simon.I'll have to see what happens at the weekend, but I don't plan to deliberately drive through deep puddles!
Simon is correct about thermal contraction as the down pipe fractured just below the weld onto the triangular flange and I came out with an open exhaust just below the turbo - that really was an "Exhaust making sound it shouldn't" .. Simon_P wrote: Elanlover,
I appreciate that you are the other side of the pond so actually have a Cat, but most elans don't so pre-cat eliminator is a figure of speech. I believe those that did hollow out their Cat did so (however misguided) in search of flow, rather than of necessity.
The ceramic substrate, where fitted, should be good for 200K miles.
Elanlover wrote:Simon_P wrote: Elanlover,
I didn't think that UK versions came with a cat but I couldn't recall. As for the catalyst material inside, mine certainly didn't last 200K miles. Not even close.
Saltire wrote:
Kathryn's is an S2 like mine, with factory fitted cat and O2 sensor.
