Great team work solving this problemisuzuowner wrote:Is there any reason that none of you are using the water pump that was designed for use with the early version of the 4XE1 DOHC engine?
Remember? The Elan engine is based on the 87-89 Gemini JT190 (89 I-Mark RS). With the hydraulic valve lifters and smaller water pump. Before the engine was redesigned for the Storm, Impulse, Stylus, and Gemini...
Gates PN 41056
http://www.rockauto.com/info/64/41056-1_TOP_A.jpg
Beck Arnley 1312064
http://www.rockauto.com/info/31/1312064.jpg
Carter FP1998
GMB 1402060
Cardone Select 5573613
And to the original question of "Do water pumps ever fail?"
Yes.
At roughly 80,000 miles, usually right after the timing belt has been changed.
Water pumps fail two ways.
The less dramatic failure is when they spring a leak around or out the middle of the shaft, producing a nice flow of water out the side of the engine compartment as all of the coolant goes out the leak.
The more dramatic failure is when the bearing fails and the impeller seizes and the sprocket stops turning as the cam belt continues under the power of the crankshaft. The teeth are quickly eaten off the face of the belt and the camshafts move out of sequence. Then you get to pray none of the valves bent.
Good question! In my case because somebody on this site listed the parts to order from Rock Auto and I blindly followed that advice. The pump you identify (41056) is currently listed at £69.48 whilst the Gates Pump 41053 is £20.31. On my Invoice from May 2016 it's shown as £16.96 so that might explain why somebody considered that was 'the one to buy'. Could be their intention was to replace cambelt and water pump every 5 years so a cheap pump will do.Users browsing this forum: No registered users and 5 guests
