Giniw wrote:Yes but mine is not chipped, it just has a stock S2 ECM.
The S2 ECM is a closed loop/CAT unit so that should work. Around 50% of the SE models have the wiring for the O2 sensor but the WIKI will explain what to check to make sure the O2 sensor is actually connected.
Alan offers an Everest chip for the early non closed loop and a different one for the closed loop with CAT. He even has the basic S2/FED program for those that want closed loop without the boost improvements.
how is your football team doing
