Any cheap solutions for LHD headlamps?
I know this is bound to be difficult as I am feeling FAR too smug after finishing my cambelt change....
It would also be good to hear what the Lotus scene looks like in Normandy.
GeoffSmith wrote:Check out Will's thread.
madbilly wrote:I just wrote a long reply and my phone lost it! I'll write up on the thread I started all those years ago...
For the CoC I can remove the sensitive parts from mine and send it to you as a proforma, let me know.
http://www.lotuscars.com/about-us/contact-us
Archive
CONTACT FOR:
Archive queries relating to build specification, build dates, certificate of provenance and data certificates for cars prior to 1997
EMAIL:
archive@lotuscars.com
Really?max-walls wrote:On the up-side, I have got a couple of French dipped-beam units off the Lotus after-sales list for £6 + VAT each![]()
madbilly wrote:Please don't apologise for my own cack-handedness! In fact I rewrote pretty much all of it as a reply in the thread I started a while ago so you can read it there.
You can find the sanitised scans of the documents here. Lotus should have the original Word versions from which they can create your documents from. If your car is an S2 I suspect the information will be different. Please tell me know if you see any personal information that I've failed to remove!
They didn't inspect my car, so I don't suppose it's necessary to worry about modifications.
I am not too sure about the dip beams.Brit-Car-Nut wrote:In the US they are readily available. I am assuming a LHD headlamp is the same as France...
/ light
shadow / light
________/ light
light lightBrit-Car-Nut wrote:What I looked for other than the Lotus supplied, dip beams for France was the main beam unit which I wasn't aware had a special beam pattern. I thought it was just the dip beam that was unique.
I must admit I thought I only need to worry about the dipped units as well. I will end up with a mix of clear and amber lenses, but I don't think this matters either - unless I'm mistaken?madbilly wrote:Same as mine then! Now I just need yellow main beams
Users browsing this forum: No registered users and 20 guests
