i did think the bleed nipple should be at the top ! i will try the other caliper tomorrow and take a pic in situ. any thoughts on the slight overhang of the pads ?
I' m sure someone will be along with a definitive answer
Brit-Car-Nut wrote:The bleed nipple has to be at the top if you ever expect to get all the air out of them
Rambo wrote:I just measured the piston on an old OEM caliper with a ruler and it was approx. 47 mm. WTF![]()
Confused
) you will see that the ferodo original pad and the pad that came with caliper does not reach the inner part of the disc surface, how ever when i fitted the new pad to the old caliper it fitted perfectly ! not sure if this would be an issue as the pad has full contact with disc. i guess the disc would have a inner unworn lip over time, but as disc are cheap i'm thinking having to change the pads and discs would not cost the earth.lotustonybassplayer wrote:just posted a few pics on facebook of the pads fitted to the caliper whilst it bolted to the hub. (the caliper is fitted the right way up bleed nipple at the top) you will see that the ferodo original pad and the pad that came with caliper does not reach the inner part of the disc surface, how ever when i fitted the new pad to the old caliper it fitted perfectly ! not sure if this would be an issue as the pad has full contact with disc. i guess the disc would have a inner unworn lip over time, but as disc are cheap i'm thinking having to change the pads and discs would not cost the earth.
lotustonybassplayer wrote: i still need to get the piston measured to see if indeed they are 54mm.
Bern wrote:I'm thinking of upgrading my brakes, how much of a difference has this made?
Bern.
