fuel filter location
Postby kevin31157 » Mon 31.07.2017, 17:57
HI everybody,
Pointers to the location of the fuel filter please
kevin31157
Re: fuel filter location
Postby CalElan » Mon 31.07.2017, 19:02
It's at the inbound side of the fuel tank.
Access is through the Hood stowage area.
Remove the black finishing cover that lines the whole area
There is a vertical access panel roughly in the middle of the vehicle - offset towards the side where the fuel tank is.
Remove this panel and you can see the fuel filter.
Be careful removing it.. the unions are liable to rust and it's easy to damage the fuel pipes
Hope that helps.
CalElan
Postby kevin31157 » Mon 31.07.2017, 19:07
GReat, thanks CalElan
kevin31157
Postby Rob P » Mon 31.07.2017, 19:11
According to the Service Manual - Section on Fuel System (Pg14).
Access to the Fuel filter is available after removing the roof stowage compartment floor, via a removable panel in the body to the right of the fuel tank.
Hope that helps, picture in the service manual self explanatory if you have access to these
simplify and add lightness
Rob P
Postby kevin31157 » Mon 31.07.2017, 20:56
thanks rob
kevin31157
Return to Engine
