I could probably do that little script if I had access to the web server or at least (and preferably ^^) a copy of the table which contains the posts.
Or just an example of a post that contains at least a link to photobucket in the exact format it's saved in the database.
Or I can even prototype something and then it would be adapted to the real formalism by whoever is in charge of the forum maintenance?
Well, basically it's almost already there:
viewtopic.php?f=12&t=26159&p=332592#p332591Brit-Car-Nut wrote:I don't know if it is possible, but maybe keep the photos or other content in sub folders unique to each contributor? I am assuming it will be a LOT of photos, so some way of organization would be helpful for the future?
Yes, and several files could share a common name too, so it would be safe to rename them properly, too. Not a problem either of course.
It seems there are not so much images hosted on photobucket (I was looking where I had read that and it appears it's you who wrote it
viewtopic.php?f=12&t=26159&p=332592#p332587 )
