by shakadad » Thu 17.08.2017, 21:10
Last year my clear coat started to peel pretty rapidly. Otherwise the car is in great shape. Does anyone have a recommendation about how to refinish the clear coat other than a full repaint? Thanks!
shakadad
by Rambo » Thu 17.08.2017, 21:34
You might be better off posting this in the bodywork section rather than the North American Elans For Sale section
- Don't push me
by Dave Eds » Thu 17.08.2017, 23:42
Rambo wrote:You might be better off posting this in the bodywork section rather than the North American Elans For Sale section
I can do that - even after the pub
by Brit-Car-Nut » Fri 18.08.2017, 00:40
Eliott:
You should add your location to your profile so readers know which side of the ocean you are on. I suspect you are in California, but don't want to assume that just because of the web site hosting your email. I know I answered one of your questions years ago assuming you were in the UK.
You would do best to visit a few body shops and get quotes for them to carefully remove the clear coat and then replace it with a product that will not peal.
I have heard of some using single edge razor blades and carefully scraping the coating off, but you stand a good chance of the razor digging in and making a mess of everything.
by Rambo » Fri 18.08.2017, 09:41
Dave Eds wrote:Rambo wrote:You might be better off posting this in the bodywork section rather than the North American Elans For Sale section
Well done Spud
- Don't push me
by ashm » Fri 18.08.2017, 17:22
I've got the same problem, and it looks terrible - was thinking of very carefully "colour sanding" it down to below the clear coat. If it all goes wrong and I go through to the primer, I won't really be in much worse a position than I am now, I'll just have completed some of the respray prep...
A
ashm
by par » Fri 18.08.2017, 19:20
I have done something similar on a Honda Accord Type S in the past, I removed as much of the flaking lacquer as possible with a razor blade and then wet sanded the edge with 2000 grit before applying a few coats of lacquer. This was on metallic gunmetal grey colour and it came up well, most people would not have been able to spot that anything had been done.
I would say give it a go as it cant look any worse than lacquer peel!
par
by shakadad » Fri 18.08.2017, 22:48
Rambo wrote:Dave Eds wrote:Rambo wrote:You might be better off posting this in the bodywork section rather than the North American Elans For Sale section
Well done Spud
Thanks, look like it's been moved already. New poster....
shakadad
by shakadad » Fri 18.08.2017, 22:49
Thanks, good suggestion, done...
Brit-Car-Nut wrote:Eliott:
shakadad
