simonbuk wrote:Isn't the upgrade cylinder slightly small in diameter ? So would require less fluid ?
!!cellaway wrote:Yes France it is south west near Royan. 8 hours sailing from La Rochelle. I'm starting to wonder if we could enter a Lotus Crew for one of the local regattas. I've got a Sunrise 34. Oldie but a goodie and quick enough to win on handicap. How many sailors have we got ?
cellaway wrote:I've just changed the standard rear calipers and discs for PNM. The front have hispec 4 pots and bigger discs. Bleeding the traditional way doesn't appear to give me enough pressure. The brakes work fine but do feel "soft" , I'm going to bleed the system yet again but if the pressure doesn't improve I feel I should be looking at the master cylinder. So the question is should I go for a standard or the brake "upgrade" one ?
From reading the "cheapest way to upgrade brakes" thread, I'm concerned about the amount of pedal travel and fluid that the upgrade cylinder will require.
cellaway wrote:Yes I did. I put the car on an angle. Front up on stands, easy bleed connected and it bled through after two attempts.
what are the piston sizes in the old calipers Vs the new?FunElan wrote: pedal feels just a tad soft even tho brakes function well. It’s almost like the pedal requires a lot less input too
Simon_P wrote:what are the piston sizes in the old calipers Vs the new?FunElan wrote: pedal feels just a tad soft even tho brakes function well. It’s almost like the pedal requires a lot less input too
FunElan wrote:Simon_P wrote:what are the piston sizes in the old calipers Vs the new?FunElan wrote: pedal feels just a tad soft even tho brakes function well. It’s almost like the pedal requires a lot less input too
Stock -> PNM front and rear. Great question, I didn't measure.
Spent another hour bleeding each corner, and even tried a pressure bleeder. At 13 psi the seal on the cap failed and got brake fluid all over the LHS suspension![]()
So we pressurized the cap to 3-5 psi and left it, while I pumped the pedal and dad cracked each bleed nipple. Kept getting so much air. But once we didn't get air, we thought things would be fine, the pedal was nice and firm before I started the car. Once I started it, suuuuuuper soft pedal.
I think I'll be buying a master cylinder just to have on the shelf in the case that I don't see any leakage at the caliper ends. Didn't see any leaks this last time.
lotusflasherman wrote:I think I'll be buying a master cylinder just to have on the shelf in the case that I don't see any leakage at the caliper ends. Didn't see any leaks this last time.
dapinky wrote:I have no idea which MC is used in the FED car (cross-reference wise!) - but I do know that the internals are nothing special and standard(ish) sizes to get the thing re-built with new seals.
There are undoubtedly lots of other MC's which will fit on the same servo mounting, but they will have different output ports, so will mean making up new pipes to fit their exact locations. For a UK car I can tell you what you'd need to replace, reseal or change for a different bore unit - but I haven't ever had to do such things for a USA car.
The point being that the diameter is likely to be larger which will give you less pedal pressure and greater travel.FunElan wrote:Stock -> PNM front and rear. Great question, I didn't measure.
Simon_P wrote:The point being that the diameter is likely to be larger which will give you less pedal pressure and greater travel.FunElan wrote:Stock -> PNM front and rear. Great question, I didn't measure.
