by lotos » Tue 12.09.2017, 14:26
Both of these seals, while working fine, could look better. Are they available for replacement? Both the one on the door and the matching one on the body. Thanks!
lotos on Wed 04.07.2018, 03:56, edited 1 time in total.
lotos
by theelanman » Tue 12.09.2017, 15:19
MAIN DOOR SEAL L/H A100V0115F (up to vin M 8161) £207+vat
MAIN DOOR SEAL L/H C100V0115F (vin. M8161 on) £224+vat
HOOD STOWAGE COVER SEAL D100V0119F (M8161 on) £135+vat
that was all I could find on S&J's........no R.H door stuff
by HJ2 » Tue 12.09.2017, 15:41
by lotos » Thu 14.09.2017, 16:36
Given my seals are in decent condition, is it possible to repair the surface for appearance sake? Has anyone tried a product or technique that works? Thanks.
lotos
by simonbuk » Thu 14.09.2017, 17:57
And none of those seals are anything to do with those bits in the photo are they ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by novacaine » Fri 15.09.2017, 12:14
lotos wrote:Given my seals are in decent condition, is it possible to repair the surface for appearance sake? Has anyone tried a product or technique that works? Thanks.
A little Sikaflex to fill the gaps and maybe some spray on rubber to coat the whole seal?
I've been looking at mine and thinking the same thing. I know Jamie N managed to make some rubber door seals as replacements, but im pretty sure the other seal may be Jamie's last task
novacaine
by TrevorB » Fri 15.09.2017, 14:09
You might also like to try 'Sugru', it's a mouldable rubber glue a bit like playdo. Do a search on google (there are other search engines available!) You can
purchase it from Amazon or ebay.
I've used it and found it very good for exactly that sort of problem.
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
- Wannabe Princess
by Dom » Fri 15.09.2017, 21:01
I've also found Sugru very effective. It's even a very good colour match.
Dom
by Fredjohn » Fri 15.09.2017, 22:06
Sugru readily available from your local cheapo Wilko store!
by Giniw » Fri 15.09.2017, 22:34
It seems available in small quantities/patches only though, isn't it?
Giniw
by Saltire » Fri 15.09.2017, 22:41
Yes, because an opened pack won't keep. You buy several small amounts, each in its own sealed pack, and then use one (or more) as and when you need to. It reacts with air and is pliable for about half an hour or 40 minutes before it sets hard.
by Giniw » Fri 15.09.2017, 22:43
That makes sense, thanks, but it's a pity when you need a large amount, because small tabs still seem expensive.
I gather there must be a cheaper product to mould a rubber like thing (polyurethane based probably?)
Giniw
by Neil D. » Sat 16.09.2017, 17:09
S2 # 541
Neil D.
by clemo » Sun 17.09.2017, 19:44
Many years ago i used silkaflex and cling film over the top of it .
It lasted many years . The cling film over the top made it easy to fettle the silkaflex without leaving finger prints or marks in it .
clemo
- LEC Administrator
