John_W wrote:niall,
An Elanscan log will be useful, but remember that many things that can cause a misfire will be invisible to Elanscan. It will only show up sensor faults that the ECU uses, and will not pick up wrong plug gaps, failed plug leads or incorrect static timing for instance. Those things may not set any fault code at all, or may just set a fault code that points to something else. What I mean is, don't just buy a potentially expensive new part that the fault code points to without cross-checking it.
John_W wrote:About the only thing you missed out of that is that the dog ate your soldering iron.![]()
I’m surprised that you’re not in Spain already. Or is the temperature in the balmy south a lot warmer than it is up here?
Anyway, I’m envious of you being able to go someplace warm. Have a cheapo Spanish brandy for me!
