Mike T wrote:I'm getting a slight whining noise after a cam belt change. It's the first time I've had the belt changed, so not sure if this is normal. Is this to be expected and just the new belt bedding in?
A cambelt that was over-tightened on one of my cars before I owned it resulted in the warranty rebuild of an engine at Paul Matty's - approx £4,000.00 worth so I would get it checked out.
Rambo wrote:You shouldn't be getting any noises after a cambelt change if done correctly![]()
Get it back asap
Although I am not a specialist I have changed a cambelt on two different cars already (including the Elan of course) and I haven't heard any noise afterwards.HJ2 wrote:There's always some whining after a cambelt change. It would not worry me.
[edit: added to put back the context]However it is impossible to 'hear' your noise on the interweb! For the same money the belt could be overtightened or another potential disaster is lurking around the corner...
If done by a professional... I would let him listen as well if you are really worried.
Rambo wrote:No mention by OP of a change in water pump. Perhaps he's still on the original pump(for some strange reason some people only change the cambelt and not the other stuff ie water pump, tensioner, idlers, associated belts etc...so perhaps this is the case here ??)
Thinking about it, the last time I had a cambelt and associated paraphernalia changed on my yellow car there was a whine/screech on start up after a few days that I identified as the alternator belt. I took it back to the garage who had done the work, they confirmed my prognosis, got out their tools and I was back on the road within 15 mins.
