woodcock wrote:New M100 owner but old Elan (1966) owner. Temp is at the 1/4 mark until stuck in traffic than it climbs to 3/4 mark. Fans do not come on even with A/C turned on.
When I shut the engine off the coolant pump does not come on either. Checked the fuses all OK. Any ideas ?
Ron
Giniw wrote:(A bit off topic but I don't understand why a lot of people consider the sender doen't match the gauge. To me it suits it very well since the operating temperature can be read thanks to a needle that actually moves through its available range. I can see no point in a needle that stays on the middle of the range forever? I do understand it's a bit disconcerting though, as it's quite unusual.)
Ron
rip wrote:Giniw wrote:(A bit off topic but I don't understand why a lot of people consider the sender doen't match the gauge. To me it suits it very well since the operating temperature can be read thanks to a needle that actually moves through its available range. I can see no point in a needle that stays on the middle of the range forever? I do understand it's a bit disconcerting though, as it's quite unusual.)
The gauge gives you a detailed view of the temperature in its normal operating range. Too high or too low (except when warming obviously) is a concern.
What would be the point of worrying if the temp was below 1/4 or 3/4 if the areas outside of this range are 'worry areas' anyway?
CalElan wrote:woodcock wrote:New M100 owner but old Elan (1966) owner. Temp is at the 1/4 mark until stuck in traffic than it climbs to 3/4 mark. Fans do not come on even with A/C turned on.
Ron
If you search the forums you'll find some tests - from memory, find the connection to the temp sensor (not the gauge), and short this to earth.
With ignition on the fans will run - so keep your fingers out
With the ignition off the pump will run - I can hear mine ..
Others will be along to confirm / deny
Kathryn wrote:My needle does move. As it should it soon starts to rise if I stop and the fans work as they should. I could just have wonky gauges though, because the needle on my fuel gauge never goes up to the top even when the tank is full.
