Saltire wrote:..... which leads me to wonder whether S2s on the whole run a little cooler.
Probably because they are the 'Eco' version, with low power
Giniw wrote:Yes that's not what I meant, I did understand you needle moves but you said it's mostly under the 1/4, which seems a bit low compared to my car (and most of the cars here if I am not wrong).
So if I were you I would check the actual running temperature with elanscan just to be sure.
(In any case, nothing to worry about since a thermostat is a really cheap item.)
Rambo wrote:What we really need is for El Geordie to develop a digital temperature gauge and then it won't matter what angle we view it from![]()
Saltire wrote:Rambo wrote:What we really need is for El Geordie to develop a digital temperature gauge and then it won't matter what angle we view it from![]()
I seem to remember that at one stage Our Spanish Correspondent was developing a piece of electrickery which linearised the relationship between gauge and sender; I never did hear if it went any further . . .
Steve A wrote::? I took the car for a nice A road drive yesterday and thought that the temperature looked lower than it usually is ?
If the car sat in traffic it would go up as expected and drop again when moving.
The level of the coolant in the header tank went up but I would consider that normal as it would go back down as it cooled off.
The header cap was hissing a bit but not letting by.
Today I noticed the coolant had dropped below where it had started yesterday with no signs of a leak.
I started the car and felt the radiator top hose from the thermostat, it felt warm almost straight away? I would have thought it would remain
cold for a longer period then as the thermostat opens it would get a rush of heat.
I wanting to use ElanScan to check this out but that's a whole different story.
I intend to change the thermostat and header cap a a precautionary measure, what with the big weekend coming up.
Just to top things off I decided to take it for a spin before putting it to bed and as I returned the bonnet prop the holding clip snapped
