Bern wrote:Looking at the code I can see there's a comment about changing the SERIAL_RX_BUFFER_SIZE, I hadn't done that, so I will and try it again.
Though I'm supposed to be working at the moment, so I'll have to try it later!
Bern wrote:Hi Matthias,
Thanks for the reply
I did have the ignition on before turning the logger on, but the engine wasn't running - I started the engine whilst the logger was on - would that make a difference?
I'll try it again tomorrow.
Bern.
Bern.
Another possibility: When you crank the engine, the battery voltage drops and dependent on how the Arduino supply is regulated will determine whether it continues to run until the engine starts. I originally had this problem with my Bluetooth interface (which, having software involved took forever to re-establish itself) so I designed a robust two stage regulator circuit that maintains the BT supply for a lot longer then I'd care to crank the car and the BT connection is maintained throughout.
Bern wrote:Finally found time to sort this out!
Not sure what the issue was, I re-arranged some of the program and got it to create a debug file, but then it started working anyway!
matts1972 wrote: .........Any suggestions are welcome.
Elanlover wrote:matts1972 wrote: .........Any suggestions are welcome.
Uhmmm....don't buy Chinese?
RonR wrote:Had a bit of a hiccup with the display software.
No matter what I did I couldn't get the code to fit on the Arduino Uno and run reliably, the Arduino Mega was overkill (big and expensive) so the project went on the back burner.
However a few weeks ago I discovered that there's an alternative big brother to the UNO's AtMega328 CPU that can be used with the Arduino programming environment.
CalElan wrote:Ok folks - stand by for an influx of stupid questions.
This has become my isolation project - ordered all the pieces and even found my soldering iron in the garage.
Be afraid - be very afraid!
RonR wrote:A note for other builders:
I used the prototyping area on the logger board to build the ALDL interface circuit so it's hard wired to the Tx and Rx pins. However after doing this I got the error - "Avrdude Stk500_getsync(): Not in Sync Resp=0x30" when uploading the sketch - This error can sometimes appear when something is connected to the Arduino Rx pin. Unplugging the logger board allowed me to upload successfully.
Ron
