Would I be correct in saying that :
In basic terms,
When the window comes to a physical stop the motor senses the current change and stops the power to the switch ?
Brit-Car-Nut wrote:The "UP" stops are metal brackets that the upstop cones run into and the raised electrical current from the motor stalling stops the progress.
Anything that blocks the motion of the glass will stop the motion, so a carefully placed rubber bit that will safely block the window on it's downward path will probably work.
If you duplicate the travel block idea, you will need to put two stops in place so the glass doesn't rotate/twist.
I have a door apart right now, so I will see if I can test the concept.
quality does not spring to mind, fragile does!roy666 wrote:Hi Steve - I've become a bit of an expert on repairing and replacing the window system... I've done it so may times now! I replaced the window regulator with the Peugeot 405 drive and the trick is to rewind the wires tightly and measured correctly. There is a method. I then taped together two gel keyboard wrist support strips on the base of the door..stuck down with a sikaflex. They fit quite well and now the glass stops/rests snugly/safely on the gel strips. I also blanked off the the bottom holes in the door, so its pretty much water tight... apart from some that seeps in from the window seals (which I also replaced)... not much to worry about though. The 405 regualtor is fantastic.. none the ridiculous clutch jerkiness that you get with the OEM one... its smooth and stops nicely without a jolt. I have replaced the plastic channel blocks and the current ones are going strong 4 years old. Good luck. M
