Two new suspension dampers for sale - SOLD
Postby Mutley00 » Sun 11.02.2018, 17:13
Profuse apologies, but I dont know whether they are front or rear. I cant find the reference numbers in the Deroure catalogue either.
They have the following ID marks on them, together with a lime green and a yellow sticky label:
B100C0123F
MADE 010672
8116 2974 1HB
Please eMail me if you are interested and I can send you a high res image.
Thanks and regards, Andrew
It's better to have fought and lost, than not have fought at all.
Mutley00
Re: Two new suspension dampers for sale
Postby Brit-Car-Nut » Sun 11.02.2018, 19:02
B100C0123F replaced by C100C0123F
Spring/Damper Assembly, front, USA Turbo
Notes: Blue/yellow/orange colour code - Prior to VIN R6001
Postby Mutley00 » Sun 11.02.2018, 22:31
Thanks for the info. Any idea how much they are worth. The Deroure catalogue states £290 for front dampers which seems a hell of alot of money!
Mutley00
Postby Brit-Car-Nut » Sun 11.02.2018, 22:43
SW Lotus has a fair stock of them them for 50 quid each.
Postby Simon_P » Thu 15.02.2018, 15:19
Sent a pm asking how much, the answer came back Deroure have thm for £200-£300 each.
There was a seller on ebay who was selling several pairs of these a few years ago for £30 a pair.
So I offered £30 +p+p and haven't had the courtesy of a response.
Postby Brit-Car-Nut » Thu 15.02.2018, 15:46
From The Lotus Centre On-Line:
http://www.thelotuscentreonline.co.uk/e ... C100C0123F
I have purchased several sets over the years.
Postby HJ2 » Fri 16.02.2018, 09:55
Is the ride height 5mm lower or higher as compared to the European?
Postby lotusflasherman » Fri 16.02.2018, 11:25
HJ2 wrote:Is the ride height 5mm lower or higher as compared to the European?
On the basis the MGB and XJS were 'jacked up' and fitted with huge rubber bumpers to suit the American legislation, I'd guess 'higher' ... :lol:
Re: Two new suspension dampers for sale - NOW SOLD
Postby dapinky » Sat 17.02.2018, 18:20
Yep, higher if fitted to a UK car - but less so on a FED car due to the weight of the crash structure etc at the front.
Return to Elan Parts for Sale (Used Parts For Sale)
