Paint colour for grey plastic parts
Postby Saltire » Sat 12.05.2018, 07:27
Morning all, I’ve a couple of places in the cockpit where the paint has worn off the plastic trim pieces - noticeably the top of the steering column cowl, which is a bit unsightly. Does anyone know what shade of paint was originally used for these parts (and yes, I realise it may have faded in the interim :? ), and where I can get an aerosol today?
Alternatively, has anyone tried to match it with a touch-up aerosol?
Thanks!
Re: Paint colour for grey plastic parts
Postby Jamie N » Sat 12.05.2018, 07:56
One option for getting a match on things with no known paint code is to take the part (if it's not too big) into Halfords
and just go along all the rows of paint checking against the coloured caps. ;-)
Monaco S2 #406
Jamie N
Seal God
Postby Steve A » Sat 12.05.2018, 08:07
What about autoglym bumper and trim gel ? that's stuffs magic on rubber :D
Postby Saltire » Sat 12.05.2018, 17:35
Jamie N wrote:One option for getting a match on things with no known paint code is to take the part (if it's not too big) into Halfords
Mom, I thought about that, Jamie, but a) I don’t have a Halfords within reasonable range and b) I’ve had expernces in the ast where the cap colour doesn’t match the paint colour. May have to go that way though.
Postby Saltire » Sat 12.05.2018, 17:36
Steve A wrote:What about autoglym bumper and trim gel ? that's stuffs magic on rubber :D
Good thought, but I’m not sure it will put back paint that’s been worn off?
Postby wayne » Sat 12.05.2018, 18:28
Apparently this matches, but I have no idea where to buy it from.
http://www.elanm100.com
wayne
Postby lotusflasherman » Sat 12.05.2018, 20:15
Postby John_W » Sat 12.05.2018, 20:29
Whatever you do, don’t ask Halfords to mix up a matching paint for you. I think they give the mixing job to the colour-blind trainee. I still have a pot of specially-mixed paint which bears no resemblance to Pacific Blue. If you have a proper paint shop nearby, that’s a different matter - maybe take the part in and get them to match it?
Postby Bern » Sat 12.05.2018, 22:34
When I needed to match some paint recently I picked up some Dulux colour charts (that they use for the in-shop paint mixing).
Once I'd found the closest match I looked this up here to get the RAL code.
And then using the RAL code I was able to order some mixed cellulose from eBay!
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
Postby lotusflasherman » Sun 13.05.2018, 01:45
If you want to deal with stone chips these guys are very good. Small pot of exact match paint with a brush inside for £10 ....https://www.cartouchuppaints.co.uk/KIT-1-Touch-Up-Paint-Matt-Finish
For my Pacific Blue '93 SE (made June '92) the Colour is "Pacific Blue (B08)" and the Colour Code is "DuPont ABN9144"
Postby Saltire » Sun 13.05.2018, 07:47
Thanks everybody. I followed up Wayne’s suggestion, and eventually tracked some down . . . on Amazon UK :smt107 The price was reasonable, but postage was extortionate, so I bought three cans to help justify the purchase :oops:
Give me a shout if you want one.
Will update this thread once it’s arrived and I’ve tried it.
Postby dolmerob » Tue 22.05.2018, 09:19
Sounds like a plan. Post some pictures once you're done.
dolmerob
Postby maz_r » Tue 22.05.2018, 10:02
Hi Jonathan,
Did it arrive? Does your offer of a spare can still stand, in which case, I shall be at CC...... :)
maz_r
Binary Bodger
Postby Rambo » Tue 22.05.2018, 12:44
Bern wrote:When I needed to match some paint recently I picked up some Dulux colour charts (that they use for the in-shop paint mixing).
If you want an identical colour, RAL codes are the way to go
Postby Saltire » Tue 22.05.2018, 22:28
maz_r wrote:Hi Jonathan,
Yes. And I have tried it. And it matches perfectly. And I will be at CC also . . . . . :twisted:
On the side issue, Rambo is right; RAL codes are the way to go . . . . Provided you know the RAL code you’re trying to match :cry:
Return to Interior
