HJ2 wrote:As said: try using an easybleed or a proper brake bleeder.
In the end it will work!
Fredjohn wrote:as Geoff says, tighten the banjo properly, that's probably where air is getting in....
).Bern wrote: I left it overnight with the brake pedal held down, and in the morning it was fine! Depending on where the air is, that might work!
Giniw wrote:If I remember correctly the bleed nipples are still available from sjsportscar (and probably deroure?). Or at least they were, not so long ago.
Saltire wrote:Rock Auto have lots of alternatives to choose from at prices much less than SJ (under Isuzu Impulse Turbo). There are also some NGK ones on eBay at the moment.
Rambo wrote:As Jonathon and Dave have previously mentioned, don't t spend £££ when you can easily get the coil packs from EBay.
But first, try Dave's suggestion and swap out the good coil packs from your blue M100 before going further
