cshtelecaster wrote:please can anyone suggest anything ..Im a relatively new member, got my elan around 5 weeks ago, the very first time I turned the key it sounded terrible, drove it running very rough then decided to rev it when pulling away and suddenly it seemed to clear , it then ran fantastic for a week before developing the same issue. did check sparks, seemed low on no1, swapped plugs one and 2 over. started engine ,fantastic,drove about 3 miles, accelerated quickly and problem returned..have now replaced all plugs,leads, and both coil packs,,start engine ad will idle fine when warm .if I press the accelerator its rough from idle to about 2500 rpm,,,over that seems to be ok,, just not sure what to check ,or if to give to garage,,,,on another note does anyone know of a mechanic or garage near Gloucester ...getting sad because I really want to enjoy my elan, those few times it ran well were great and put a big smile on my face,,
chris
Simon_P wrote:First two things to before you do anything are checking the base timing and the idle.
See the wiki
ElanBRG wrote:Simon_P wrote:First two things to before you do anything are checking the base timing and the idle.
See the wiki
If the base timing and idle were set incorrectly, that wouldn't result in an intermittent issue where the car runs great for a week and then bad again. It would just be bad all the time.
Something else is going on.
Simon_P wrote:ElanBRG wrote:Simon_P wrote:First two things to before you do anything are checking the base timing and the idle.
See the wiki
The car is new to him so it would be prudent to ensure that they are correct first. Plus it is free.
GeoffSmith wrote:Simon_P wrote:First two things to before you do anything are checking the base timing and the idle.
Users browsing this forum: NickVR6 and 9 guests
