par wrote:basher wrote:
which ones are you fitting to the leading edge of the hood?
thanks
Mike
I was lucky enough to get one of Jamies combined header & A pillar seals, think it was a development/prototype set but it fitted perfectly.
I used this seal for the leading edge of the hood:-
https://www.amazon.co.uk/gp/product/B01FSE3G3U/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
It provides a good rubber on rubber seal which I have tested and doesnt let any water in but I do intend to adjust the roof catches to increase the clamping force and lower the front edge of the hood as advised by the Seal Master himself. I believe the under bonnet seal from a Toyota Aygo is also a good fit.
Steve A wrote:
What are you using for the two front seals that were apart of the old header seal
Scott J who owned the car prior to me had previously comissioned Jamie to replace the A-pillar & intermediate seals with EPDM versions and at the same time the front sides were replaced with EPDM versions also crafted by Jamie. In terms of my cars hood it is only the falling pillar seals that remain of the soakupalot sponge material.
. (logo only indicating what they are for
Saltire wrote:I have them, Clemo. And they do mate up with the front one. And they’re brilliant - although they do take quite a bit of fettling to achieve a good fit all round. Thoroughly recommended.
lotusnut wrote:How can I get set please
