Tuga2112 wrote:I've confirmed the problem to be the lift control unit (forgot technical name of the box)
Recorded a very crude video for YouTube to help the diagnostic process for others. Will be updating here soon
John_W wrote:Brit-Car-Nut wrote:You guys can always host the photos yourselves and then provide a link...
That’s what I used to do until my Internet provider decided that they didn’t want to host anybody’s webspace any more. TalkTalk - don’t ya love them? I don’t.
Just click on the internet symbol under my avatar to see their friendly message. £43.50 a month for an internet speed of 1.3 megabits/sec and now no web hosting. Barstewards.
i share your thoughts on the topic. originally i used a provider called imageshack. which gone the exact same route as photobucketGeoffSmith wrote:John_W wrote:Brit-Car-Nut wrote:You guys can always host the photos yourselves and then provide a link...
Yep. But then there's useful free resources like Photobucket… who after accumulating a vast library of other people's useful stuff now want to charge for other people to see it. At the moment, I use Imgur.com but I wonder how long it will be before the ugly head of capitalism rears its ugly heed.
Rambo wrote:Why not swap over a working pod module from your other car then you'll be able to confirm if it's a duffer
Brit-Car-Nut wrote:Two things have been shown to happen to the modules: Drive transistors burned and the relay inside breaking.
Next time, take high detailed pictures of both sides of the circuit board so we can see everything n one view. We can look at section after section and see the continuity.
One or two pictures of each side of the entire board is better than a few pictures of different sections. Paul's pictures are well lit and clearly show an overheated drive chip.
Sometimes, bouncing between different posts will get people confused as they try to figure out what is now and what is history.
Brit-Car-Nut wrote:I agree with RAMBO. Use the module from your other car to verify the module is even the cause.
Brit-Car-Nut wrote:DID YOU SWAP THE CONTROLLERS?
Brit-Car-Nut wrote:If you did and the lights work correctly, then the controller is bad. Simple. Replace the bad one.
Brit-Car-Nut wrote:If you just forced a different power or ground/earth to test the motors, then you still don't know what the problem is.
Brit-Car-Nut wrote:Some days, you just have to replace parts. Keeping a car like the M100 safely on the road is a challenge and because the parts are very expensive, it can be a financial disaster.
Always pushing for the absolute inexpensive repair requires a huge amount of work finding a source of the RIGHT parts and often skills in a lot of different professions.
I respect trying to get the car fixed for little money, but you are trying to learn how to test, analyze, source and make the repair with very little background in the various processes.
In my 50+ years of car ownership and eventual running of several dealer repair centers and finally my own company, I have spent an enormous amount of time repairing work owners attempted so they could save money only to end up with a bill that was more than the original cost to repair.
Brit-Car-Nut wrote:Honestly, you can't fix everything without a significant amount of experience in the systems and logic required to make the repair correctly. I applaud your efforts, but sometimes, you just need to replace the defective part.
Tuga2112 wrote:the power-earth combination i used is the exact same that the unit would redirect to the motors i used the purple wires, because according to the wiring diagram, those are the ones fused at 15amps on top of the instrument cluster.
Tuga2112 wrote:.... in my opinion, if SJS can refurbish them.. i dont see how i cant... its just a matter of learning enought about the subject untill im capable of diagnosing the system.
Tuga2112 wrote:when you say it uses 4000 series logic, (which i have just googled) i assume your refering to the 4001 IC with ST written on it. is that correct ?
do you know what is the other IC ? i tried to find datasheets for it without any luck.
GeoffSmith wrote:Correct - the 4001 is a quad 2 input NOR.
GeoffSmith wrote:16511949 is probably a GM part number and therefore a custom device that you are unlikely to find anywhere other than in a GM headlight module. Date code appears to be 8931 so manufactured in 1989.
GeoffSmith wrote:PS if anyone wants to lend me a left hooker for the Winter, I can probably take a look.
Tuga2112 wrote:GeoffSmith wrote:Correct - the 4001 is a quad 2 input NOR.
you probably quoted me before i edited my post. (and possibly made it wrong?)
the IC i found when googling for the data printed was a quad 2 input NAND (which according to my further googling is a 4011)
i need to do some further googling to learn how to test the IC, i have a suspicion of a process that could work, but given the fragility of the parts i will be googling further on the topic before doing anything else.
Tuga2112 wrote:GeoffSmith wrote:16511949 is probably a GM part number and therefore a custom device that you are unlikely to find anywhere other than in a GM headlight module. Date code appears to be 8931 so manufactured in 1989.
the only other reference i found of this IC was on the corvette forum https://www.corvetteforum.com/forums/c5 ... d-why.html where they suggested the same
upon close inspection i found a cracked solder joint. which was rectified but proved to not be the culprit of the failure.
Tuga2112 wrote:GeoffSmith wrote:PS if anyone wants to lend me a left hooker for the Winter, I can probably take a look.
not sure if your asking for a bribe, or a spare unit... (blame it on the language barrier)
Users browsing this forum: No registered users and 24 guests
