NOS parts on Ebay
NOS parts on Ebay
Postby gherlt » Wed 16.01.2019, 08:09
Hi,
I still got a few M100 parts stored in boxes and I need space, space and ... space.
I decided to put them on Ebay, starting from 1€. They are located in Germany.
All are NOS, original Lotus and unused:
Airfilter- https://www.ebay.de/itm/303028533249
clutch cable - https://www.ebay.de/itm/303028537207
Brake pads rear - https://www.ebay.de/itm/303028559362
Speedo cable- https://www.ebay.de/itm/303030880766
bonnet release - https://www.ebay.de/itm/303030881385
rack bellows - https://www.ebay.de/itm/303030881645
throttle cable LHD - https://www.ebay.de/itm/303030881934
Ignition cable set - https://www.ebay.de/itm/303030882793
More next week
Guillermo
gherlt
Re: NOS parts on Ebay
Postby Giniw » Wed 16.01.2019, 13:51
Hi, thanks for the hint!
Would you put several items in a single parcel to save on shipping costs?
Giniw
Postby gherlt » Thu 17.01.2019, 10:02
Of course I would bundle items for shipping.
Shipping is at cost, not a hidden income.
gherlt
Postby Giniw » Thu 17.01.2019, 10:44
Thanks gherlt =)
Giniw
Postby gherlt » Thu 17.01.2019, 11:37
In the next days I will publish a list of items that I will put on eBay, so everyone can decide if it's worth delaying shipment, to include more parts.
gherlt
Postby gherlt » Thu 17.01.2019, 22:20
I already had that list, so here you go:
B100M6019F SWITCH Master Lighting (1x mit OVP)
A100M6077F Maxi Fuse 40A
A100M6078F Maxi Fuse 50A
A100E6054F M.A.P. Sensor
A100E6271S NGK BPR5EY-11 Spark Plug
A100C6009F Bearing, front hub
A100M6069F relais ???
C100B0607F CABLE FILLER CAP RELEASE
B100M0083F Lamp Side Repeater
B100M6004F REAR FOG LAMP SWITCH
A100B0436F Cone Retainer-Door Glass
A100E6171S Oil Filler Cap
A100E6284S Gasket Cam Cover
A100K6008F Filler Cap - Header TankB2
A100M6015F Mini Relay (ECM,FUEL PUMP,HORN)
A100B1042 Spacer-Glass Guide
B100M6005F A/C Switch
A100K0038F Hose-Thermostat/Tank
D100B0039F Guide Brkt-Lower Rear LH
D100B0038F Guide Brkt-Lower Rear RH
A100M0049F Lamp-Number Plate
A100R6010S grease inboard Joint
A100B6159F Spring-Headlamp Adjuster
C100M0065F MODULE CDL CONTROL
A100B1233 F PLATE GLASS MOUNT LH
A100B1234 F PLATE GLASS MOUNT RH
A100S6011F Exhaust Clamp
A100E6176S Thermostat NA/TURBO
A100R6009S Grease
A100L0047F Vacuum Solenoid Valve
B100B1125F SIDE SCREEN
B100B1126F SIDE SCREEN
T000T0899F KENT MOORE J34730-C PORT FUEL INJECTION DIAGNOSTIC KIT
T000T0909J ALDL Bridge ConnectorBP
A100J0020F Handbrake Lever
C100J0019F Handbrake Mounting
NOS ignition lock with 2 keys
All these parts will go on ebay, starting with 1eur.
Pictures available here:
https://photos.app.goo.gl/G1TwoEhcWyvPirTi8
gherlt
Postby Giniw » Thu 17.01.2019, 22:42
This is a nice collection you have!
(Didn't you have a nice silver frost Elan for sale about 6 years back by any chance? I remember I exchanged a few emails with a German guy before I found the one I bought in the Netherlands and I think I remember he was part time in Spain too)
Giniw
Postby gherlt » Fri 18.01.2019, 07:21
Hello Giniw,
yes, that was me.
I had one pacific blue (#6724) and later the silver (#7003). Great cars.
I see an M100 and always think, shouldn't have sold any.
But buying house (2000) and crisis (2011/2012?) really left no room for choices.
Guillermo
gherlt
Postby gherlt » Sun 24.02.2019, 21:32
Hi all,
I now posted the last batch of M100 parts.
Please take a look here:
https://www.ebay.de/sch/gherlt_es/m.htm ... pg=&_from=
Shipping of multiple items will be combined.
Guillermo
gherlt
Postby Brit-Car-Nut » Sun 24.02.2019, 22:56
Thanks, but could you please put some English in the listings? Google translate doesn't do very well with eBay listings.
The majority of potential buyers are in the UK & US and the next most common language is French.
Postby lotusrepair » Mon 25.02.2019, 07:24
Your ebay listings are not allowing for shipping to the USA. Will you ship these items to the USA?
lotusrepair
Postby gherlt » Tue 26.02.2019, 07:40
Brit-Car-Nut wrote:Thanks, but could you please put some English in the listings? Google translate doesn't do very well with eBay listings.
In most cases the english parts name is listed in the description.
gherlt
Postby gherlt » Tue 26.02.2019, 07:47
lotusrepair wrote:Your ebay listings are not allowing for shipping to the USA. Will you ship these items to the USA?
Yes, I will ship anywhere.
At the moment of listing the items I did not know of a new shipping service offered by DHL,
which delivers small items (up to 1kg) for 9,50€ worldwide.
I would like to correct shipping costs of my listings, but I can't as bids are already placed.
So, if you bid on small parts(and all together are below 1kg), be assured that I will only charge 9,5€.
Please request payment detail (or invoice, I do not know how it is called in english) and I will change to shipping amount.
gherlt
Return to Elan Parts for Sale (New Parts For Sale)
