Replacement gas cap
Replacement gas cap
Postby Sleeka » Fri 29.03.2019, 06:10
Just wondering if anyone knows of a compatible gas cap in North America. I haven't found one in any of the auto parts sites yet. I figure there is probably a more common car that has the same cap.
The reason I ask is I left the cap on the trunk lid and drove away. Not my best moment. I tried a search but it must be called something else in Europe as there aren't a lot of topics on "Gas Cap"
Sleeka
Re: Replacement gas cap
Postby Saltire » Fri 29.03.2019, 07:22
Try “fuel cap”, “filler cap”, or “petrol cap”.
And look here
Postby theelanman » Fri 29.03.2019, 07:55
if they cant help.....
Ive got a couple....... :-D
Postby John_W » Fri 29.03.2019, 11:55
Picked them up off the ground in a filling station near Donington, Hethel or Castle Combe?
Postby Brit-Car-Nut » Fri 29.03.2019, 12:55
My inventory says I have 2 new caps in stock. I will confirm this later today. If I do, $15.00 + postage if it will help.
Postby donsladek » Fri 29.03.2019, 15:35
Would be nice if a replacement cap with a tether was available...
Don Sladek
Calypso Red '91 #37594
donsladek
Postby donsladek » Fri 29.03.2019, 17:08
John - I tried this, but now my CEL comes on and the cap bounce off my chest when driving... :poke:
Don Sladek
donsladek
Postby GeoffSmith » Fri 29.03.2019, 18:48
So is mine the only one?
Postby Rambo » Fri 29.03.2019, 19:54
Surprised you need that El Geoffos. You hardly ever drive the garage queen what with all the time you spend in Sangrialand :twisted:
PS is that a standard ie OEM petrol cap ?
PPS your door to rear panels/rear deck shutlines look awfully big. Is that just an optical illusion or do I need to go to Specsavers ?
Postby GeoffSmith » Fri 29.03.2019, 20:01
You're right, but it's a convenient place to keep the lawnmower fuel.
It's OEM for a 2006 Nissan Micra. And an OEM VW cap will do the same thing… unless you want to retain the originality. ;)
It's not an optical illusion and (as the medical profession have told you on many occasions) it's as good as it can be for someone of your age: The door and stowage hood are both open.
Postby John_W » Fri 29.03.2019, 20:10
That doesn’t look like any Elan filler cap I’ve see before. Do tell where you got it. As the age of owners increases we’ll probably all need one, as we’ll either forget where we put it, like Don, or forget why we came to the Shell station in the first place.
Postby Rambo » Fri 29.03.2019, 22:06
John - I got quute a few a couple of years ago at Donington. SW Lotus were virtually giving them away so I bought some and.... well, gave them away. None left, unsurprisingly :?
Postby John_W » Fri 29.03.2019, 22:33
You mean you finally got to the end of the set of spares for when you forget them at the petrol station?
Just to pass on a tip, I find that a bit of string between your gloves and passed up the arms of your coat does wonders for not losing them.
Postby Rambo » Sat 30.03.2019, 04:50
In nearly 40 years of driving I've never lost a petrol cap. Or left one lying in a petrol station. Despite never owning a petrol cap with a rubber band :?
PS :offtopic: I know, but the gloves on string was very useful when you were at infant school. So what about your beanie (that's Scottish for woolly hat ie "yer beanie" or "yer bunnet") John ? Is that held on "yer heid" by a bit of string ?
Postby donsladek » Wed 17.04.2019, 18:39
I recently ordered and installed a Motorad MGC-835T fuel cap with tether from RockAuto - picture attached.
I attached the tether to the lower screw on the fuel door hinge, with the tether routed rearward to prevent it sticking out below the door when closed.
The cap hangs below the wheelwell during fueling.
Don Sladek
donsladek
Postby Sleeka » Wed 17.04.2019, 21:35
I have it sorted now.
That is a good find though. Is there a cross reference for items like this to live for people like me. I know there is the one on Golden Gate club but it's not updated.
Sleeka
