Max timing adjustment
Postby Hoppo » Thu 11.04.2019, 20:44
When I first picked up my project it started and ran but would not drive under load. It would miss and back fire etc.
On checking the timing it was at around 1 ° advance.
So following the procedure to adjust I've got it to 16° just but the CAS is on its max adjustment.
The car now runs a dream. Pulls like a train starts first flick of the key but it cant be right to have it that far adjusted.
Best guess is the belt is a tooth out on one cam but it runs so well I'm reluctant to mess with it.
Hoppo
Re: Max timing adjustment
Postby Simon_P » Thu 11.04.2019, 21:39
1 degree error wouldn't be detectable.
Just checking that you did it in service mode?
Full adjustment would be more than one tooth out.
Postby Hoppo » Fri 12.04.2019, 09:42
Yeah in service mode.
Hoppo
Return to Engine
Users browsing this forum: Bing [Bot] and 1 guest
