Replacing the tape around the base of the hood
Postby e42 » Fri 17.05.2019, 15:49
Good afternoon all,
The sticky-backed vinyl 'tape' that runs around the base of the hood (S1 SE) is perished, does anyone know where I could get some similar tape to replace this with?
Also, I managed to shear off a couple of the scrivets when removing the hood storage compartment floor to access the fuel pump, are these still available?
Thanks in advance,
Dom
e42
Re: Replacing the tape around the base of the hood
Postby Saltire » Fri 17.05.2019, 16:44
Postby e42 » Fri 17.05.2019, 17:53
Great, thanks, although with the delivery charge I’ll wait until I have a bigger order!
Dom
e42
Postby Kipperozzy » Fri 17.05.2019, 19:06
eBay sells them as well
Kipperozzy
Postby Rambo » Fri 17.05.2019, 19:08
Saltire wrote:Like these?
Very expensive :shock: Go with EBay
Postby e42 » Fri 17.05.2019, 19:56
eBay sounds a good call, thanks!
Dom
e42
Postby LRS7 » Fri 17.05.2019, 22:52
Dom, if your coming to CC I may have some of these you can have
Range Rover Vogue
Range Rover Evoque
Lotus Exige S2
Suzuki Bandit
LRS7
Postby e42 » Sat 18.05.2019, 07:13
Hi, thanks for the offer, but I found some on Amazon quite cheap with free delivery! I’m hoping to make CC coincidentally to have a look at Jamie’s seals if he’s there, in with the general interest for the day!
Thanks,
Dom
e42
