reaction, I called up my bud who I bought this short block from and asked him what the crap? He told me he saw the same thing and had the same
reaction, called up Crower and asked them what the crap? Crower's response was that those jets become unnecessary if forged pistons are being used as they are more resilient to the heat loads of the engine. I can believe that the forged pistons are more durable and ready for the task, but I've still tossed and turned about whether that means it's okay for the cylinder bores, especially since mine's bored passed the shop spec. Maybe enough oil is flung onto it from the crankshaft as it's squeezing out of the rod bearings? That's not something I have any experience or judgment about though.lotusflasherman wrote:Chris,
Seemed to have missed your updates on this thread…Interesting points you've covered in your last couple of posts.
Turbulent flow - I think very bad in a cooling system. Turbulence will cause a variation in flow and pressure and a drop in pressure can lead to spontaneous boiling of water in contact with the combustion chamber.
Oil way – ‘hole with ears’.. That makes a lot of sense and maybe explains why the bolt sits in the centre of that ‘oversize hole’. By sitting in the centre it will pull down the seal more evenly.
Your comment on ‘designing and manufacturing engines’… err, well, almost…
I’ve got a lot of experience with various engines, starting in my early teens with old motorcycles – I got hold of a Norton Dominator 650SS for nothing and my pals got Triumph Tiger 110’s which seemed a bit quicker. We were only ‘grasstrack racing’ on a large bit of wasteland so I stripped everything off, but in search of more power I found the “Design and Tuning of Competition Engines" by Philip H Smith in my local library and got addicted.
My sister, older by 4 years, bought a Ford 100E Anglia with 1172cc sidevalve engine but let it freeze up in the winter of ’63 and the head bent. I helped out by buying Mr Smith’s “The Ford Ten Competition Engine” and UK magazine ‘Cars and Car Conversions’ that had a series of articles on tuning that engine, and others; adverts from major tuning companies and a huge ‘For Sale’ section at the back, and we bought a complete engine with every Aquaplane upgrade on it. That left me with the ‘headless engine’ to play with so I polished the crank, lightened, polished and balanced the con rods and pistons and then bought a Willment OHIV head, so I had a ‘state of the art’ competition engine. Put it into sister’s car and within a few hundred miles it took the teeth off first gear – Oops! Bit tricky when the car only had 3 gears to start with. Sister bought a Mini while I was sorting that out but said she preferred the Mini if I could make it go faster, which I did.
One of her boyfriends was ‘an upper class twit’ with a Healey 3000 and a Formula Junior car and he asked me to help rebuild the Weslake BMC A series engine in that. My first look inside a professionally produced race engine. Interesting to see the oil pump and oilways into the block had ‘been flowed’, lobes on the water pump reduced and a really BIG pulley on the dynamo. The head was everything Mr Smith had said it should be.
When I became old enough to drive, the 100E went back on the road with the Aquaplane engine and 4 speed gearbox and once I’d passed my test I went looking at Lotus 7’s with 1172cc engine. Found a Lotus 6 going cheap as it had been used for organised grasstrack racing using a “Holbay 997cc ‘screamer” that had put a rod through the block. Had an aeroscreen, no windscreen, no wipers, sidescreens, hood or heater and had a 7 rear axle / suspension arrangement rather than the torque tube / panhard rod of the 6. Put the Wilment OHIV engine in the 6 for a lot of fun in the summer and in the autumn started to dismantle the Holbay engine to see what parts I could sell. That was very interesting.
Went to Brands Hatch to mechanic for ‘upper class twit’ and in the paddock we were next to some guys from close to home who were racing a Mini for the first time. I got chatting and we arranged to meet in a local pub. Spent a few weeks sharing ideas about engines and formed a two car team for next season and with our home-made engines were consistently on the podium and won the 1000cc Mini Miglia Championship a couple of times between 1971 and 76. The 998cc engine we used came out the factory with 38 bhp and we were getting mid 90’s at the wheels on a rolling road. Lots of copied ideas but most of what we did I found in Mr Smith’s book. I bought an updated 6th Edition (1977) when it came out as it had added a section on Turbochargers.
I’d recommend that as essential reading for anybody going into uncharted waters -
www.ebay.com/itm/NEW-The-Design-and-Tuning-of-Competition-Engines-by-Philip-H-Smith-Paperback-Bo-/391420428499
Uk ebay here for Dave – http://www.ebay.co.uk/itm/The-Design-an ... 1541015829
I put 130,000 miles on my first SE and 40,000 on the next two so done 170,000 Elan miles but never had the head off an 4XE1 engine so I’m no help on anything specific on that. Tried looking at the pictures in the Service & Parts Manuals but they don’t give me the detail I need.
On the subject of oiling the bores –the majority of longstroke bike and car engines had a big end shell with a hole to let oil up the rod’s oilway. Some had pressure feed to the small end as well as spraying the bores.
Short stroke and high revving competition engines usually have a solid con rod without oilway as this would weaken it so they rely on oil mist spray lubrication. Also race engines, usually, have bigger bore clearance, more piston slap, and rely on ring sealing.
I was trying to find some info in Smith’s book but quite a while since I read it, though I did come across something in the chapter about the Cosworth BDA (page 434) that I found ‘interesting’.. – “Cosworth engines in kit form have pistons with only partially machined crowns. These can be machined to achieve any desired compression ratio. However, at ratios of 12:1 or above it is necessary to use ‘O’ rings around the cylinders in addition to the normal sandwich type cylinder head gasket.”
The Elan Turbo mechanical CR is 8.5:1 but increased by standard turbo boost of 0.65 bar (0.64 atm) so when on full throttle and full boost the CR would end up at 8.5 x 1.64 = 13.95. There may be induction inefficiency that restricts that a bit but it looks like the standard head gasket is already ‘sailing close to the wind’. Wondered why so many head gasket failures appear on the forum.
Perhaps I won’t increase my boost.
There's also a few pages in Smith's book discussing pistons, materials and surface finishing and what's best for oil retention for lubrication...
