Fredjohn wrote:Before trying to dismantle the mirror have you checked you have power to all the elements of the switch? Check the wiring diagram which is available from the link in BCN's post above, (LOTUS MANUALS bit). Wiring diagrams section P21.
Also, sorry to ask an obvious question, but did you press the little rocker switch next to the rocker pad to change from right to left?
You may have a faulty earth somewhere as is often the case with fibreglass cars, so check continuity of the earth circuits too.
its a good job to do on a hot day as you are more likely to break the plastic mount in this cold weather.scotlan wrote:I won't risk breaking a mirror glass
Brit-Car-Nut wrote:I was answering his only one movement issue.
Does the RH mirror motor run when trying to adjust both directions? It should make the same sound up/down or in/out.
Do any of the connection wires look to be damaged?
Here is the circuit diagram:
quiksilva wrote:Crikey you lot don't hang around!
Looks like they are all gone and i bet it wasn't for a rush of frontera drivers,..
andy
