It’s only a small leak, honest
Re: It’s only a small leak, honest
Postby Simon_P » Fri 20.03.2020, 02:49
Jonathan, you won't need to do more research that paint chip is wrong, which isn't unusual for lotus BRG. That looks like the 60s BRG L01 but order L01 and you get an almost lime green then you discover that Lotus had four versions of BRG in the 60s - been there!
Car paint colour is a black art, even if they did have the right formula, chances are it would be remixed as the original pigments won't be available. Add to that a modern base from a different manufacturer and your 30 year old paint and the two won't match exactly.
Are they doing some work or just mixing paint?
In essence you should ask them to match what is on the car. But you also need to know if you want a clear coat and if for the bumper flex additive... 2 pack, water based or cellulose?!
Postby TorqueHorse » Fri 20.03.2020, 02:58
yeah...everything Simon_P said, as evidenced by the armchair sleuthing I did try before he wrote that ;)
The part that stood out to me was the fact that it calls it "New BRG". That opened a rabbit hole of divergence on the web calling it "Lotus New Racing Green (LNRG)" as well just BRG. And I don't know if it would make that much of a difference, but two sources had different primer shade values called out: 5 vs 7. But in the end, it seems like there is an acceptable variance for any color and that the color chip guides are just to get the painter in the ball park, but then they finish the tinting by eye (or machine). So maybe the true BRG is just...whatever works with the rest of your car :-D :smt016 :smt106 . Good luck with getting the match you want :mrgreen:
'91 FED M100 -rolling resto
Postby dapinky » Fri 20.03.2020, 10:55
Like Geoff, I have seen your car and never thought it looked anything other than 'standard' Lotus BRG....
Postby Saltire » Fri 20.03.2020, 22:09
[Internet’s been down all day in our neck of the woods, so only just seen the replies]
Thanks all. That’s what I suspected. I’m going to see the coachworks on Monday (assuming I’m still allowed to) and I’ll take it from there. But it’s reassuring to know that I’m not imagining things ;-)
Postby Rambo » Sat 21.03.2020, 10:02
dapinky wrote:Like Geoff, I have seen your car and never thought it looked anything other than 'standard' Lotus BRG....
Yeah, it looks Bog standard Racing Green to me too
Postby Saltire » Sat 21.03.2020, 10:16
So that’s what BRG stands for: Bog Roll Green
Very rare colour at the moment, I gather :lol:
Postby Rambo » Sat 21.03.2020, 10:58
Bog Roll Green
Collapso Red
Norfolk Custard
Fellatio Purple
Postby Fredjohn » Sat 21.03.2020, 11:14
Monaco white
Postby Simon_P » Sat 21.03.2020, 11:29
ErrrmPinky Green? (is that black?)
Postby GeoffSmith » Sat 21.03.2020, 11:45
No, it's blue.
Postby Rambo » Sat 21.03.2020, 13:56
GeoffSmith wrote:No, it's blue.
Looks more black than blue to me :wink:
Postby dapinky » Sun 22.03.2020, 22:44
Nah, It's mint green :D
Postby Simon_P » Sun 22.03.2020, 23:18
Sort of dark mint... Almost looks black.
Postby Rambo » Mon 23.03.2020, 10:55
Thinking of painting my garage doors Empire Green :wink:
https://images.app.goo.gl/HH2ZQG43hxBXiuh99
Postby dapinky » Mon 23.03.2020, 12:34
Simon_P wrote:Sort of dark mint... Almost looks black.
But should be white?????
Postby Simon_P » Mon 23.03.2020, 15:56
Rambo wrote:Thinking of painting my garage doors Empire Green :wink:
I've painted mine British Racing Green RAL6005 which is quite dark.
Postby Simon_P » Mon 23.03.2020, 16:03
Dapinky, being pedantic that would be Imperial Green rather than Lotus ErrmPinky Green which has a bluish undertone and looks black.
Postby GeoffSmith » Mon 23.03.2020, 16:26
That's the one. With a hint of pink. :smt044
Postby dapinky » Mon 23.03.2020, 17:41
Simon,
I take your 'pedantic', and raise you a 'didactic' :D
... Imperial Green is a Vauxhall/Opel colour with a paint code of GM355....
.... When Lotus wanted to use the same colour on it's other models, they weren't allowed to use the name "Imperial green", as GM claimed it was their colour...
... as such, they called it "Empire Green" in the brochures, but it retains the paint code GM355...
The only difference known is that Vauxhall used a grey primer, whilst Lotus used a beige one - but the actual 'darkness' of the final colour is dependent on the thickness of the paint film (mine had 3 coats, but I would have preferred another one on top to make it a tad darker..... will get it done one day)
Postby Simon_P » Mon 23.03.2020, 23:13
I think I'm with Geoff's really really obscure comment.
