in 2020?On the other hand, please don’t stop, because I’m greatly enjoying the banter
in 2020?
GeoffSmith wrote:Well, my coolant is blue.
Pinky's car is blue.
QED
japtojo wrote:What is the correct level for the coolant to be in the header tank.Cheers
Fredjohn wrote:japtojo wrote:What is the correct level for the coolant to be in the header tank.Cheers
The moulded line on the tank with 'full' written next to it!
No! See below.Saltire wrote:Please can I have the prize for the OP whose thread has strayed furthestin 2020?
The OP raised the question of paint codes.Brit-Car-Nut wrote:I'm still having a bit of a struggle trying to figure out how a coolant leak evolved into a paint code discussion.
I did say Geoff was being really really obscure.dapinky wrote:You are correct that my car is blue, '
use blue primer.dapinky wrote:"Unicorn Tears"....... (Paint code GM355)
GeoffSmith wrote:32.03A #40 - A910E6490F Hose clip 15/20mm, low pressure hose securing (PAS).
No - the 15/20mm is the size range.GeoffSmith wrote:Interesting that the pipe is 16mm OD yet the P clip is clearly stamped 15mm - possibly the reason why it's sheared.
Simon_P wrote:No - the 15/20mm is the size range.GeoffSmith wrote:Interesting that the pipe is 16mm OD yet the P clip is clearly stamped 15mm - possibly the reason why it's sheared.
and continue to hijack it mercilessly.
