Pinky II
Re: Pinky II
Postby Monty » Wed 14.09.2011, 22:36
surfboardfiller wrote:Nige had a problem with his, something to do with the handbrake and pinching a seal. :?
I'll ask him tomorrow.
LMAO :lol:
Waiting for the replacement calipers :wink:
Re: Pinky II
Postby surfboardfiller » Thu 29.09.2011, 23:26
LMAO :lol:
Doesn't take much to make you laugh your ass off then Monty, god knows what would happen if someone told you a joke, you'd probably end up in a room with no furniture. :bonk:
surfboardfiller
Re: Pinky II
Postby Rice crispy » Fri 30.09.2011, 12:00
LMAO :lol:
:lol: super fast comeback
Rice crispy
Re: Pinky II
Postby Monty » Fri 30.09.2011, 14:04
LMAO :lol:
Thats why i live in a empty house :lol:
The leak in the rear Hi-spec calipers has been a known for IIRC about a year, hence the LMAO :wink:
Got the new calipers sat here waiting to be fitted.
Re: Pinky II
Postby surfboardfiller » Wed 05.10.2011, 16:19
Wow that's incredible, I thought you were smart enough to realise not everyone spends all their time on LEC. I have a job, a life and stuff to do, judging by the size of your fat ass I'd say you don't. Laugh it up fat boy. :wink: :lol:
surfboardfiller
Re: Pinky II
Postby Nige » Wed 05.10.2011, 17:23
Bearing in mind I hadn't driven the car from Oct 09 to May 11 having crashed it and then been away from the time I got it back. The leak wasn't there when it was MOT'd in Apr 11 but was there when I had new tyres fitted 2 weeks later. The history of the leak from the problems other had made it clear what the fault was.
Back in Blighty
Nige
Re: Pinky II
Postby Rice crispy » Wed 05.10.2011, 18:43
news to me :lol:
Rice crispy
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:33
Just an update, fitted the Hi-spec rear calipers and Bob`s longer lever and Bracket a few weeks ago. Not done alot of testing, i can get 5 clicks and 6 with 2 hands. With 6 clicks the handbrake holds great, going to do more small adjustments to see if i can get it the handbrake to work at 5 clicks with one hand.
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:37
Since i was testing Dico`s none BBR beast thought i`d test my own.
Sniffer test, all clear :-D
Compression test
Warm test
Dry
#1------155
#2------150
#3------150
#4------160
Last test August 2009
WARM Engine
------Dry
#1 160
#2 150
#3 155
#4 160
Re: Pinky II
Postby bobbrown » Fri 04.11.2011, 18:44
Monty that's not that far off what it should be as the manual states 169 psi at 300 rpm, not sure what speed the starter spins the engine.
Pacific Blue N/A
bobbrown
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:54
bobbrown wrote:Monty that's not that far off what it should be as the manual states 169 psi at 300 rpm, not sure what speed the starter spins the engine.
and depends on the gauge i suppose. It`s not changed that much from last time i tested it. Just looked back and the last head gasket was back in October 2007, so now over 4 years ago and going strong :-D
Re: Pinky II
Postby bobbrown » Fri 04.11.2011, 19:04
Gauge will have a tollerance and depending on the quality the tollerance could be as much as 10%
The readings are with in 10% of each other so that's fine, bet my Elan gives higher readings :wink:
Pacific Blue N/A
bobbrown
Re: Pinky II
Postby rip » Sat 05.11.2011, 00:53
bobbrown wrote: bet my Elan gives higher readings :wink:
Wouldn't you be worried if it didn't? :poke:
Re: Pinky II
Postby bobbrown » Sat 05.11.2011, 01:20
Yes and increasing the C/R is on the cards if the head comes off as there is room to go higher like something closer to 10.8:1 or even a tad over 11:1.
Pacific Blue N/A
bobbrown
Re: Pinky II
Postby Monty » Sat 04.04.2020, 13:48
Well look who posted last :lol:
Well it's been nearly 9 years since ive posted on this thread :shock:
The Pink bomb has been sitting on skates in the garage for the past 4 years :roll: been starting her periodically but now she won't start up. Bought a new battery charge and is saying battery is fully charged. I got a small turn then just clicking.
Hoping it's not the starter?
Could the clutch be seized on? Clutch pedal is working fine.
Going to slowly get her back on the road but need to get her started as need to check radiator as there was a coolant leak somewhere. Need to strip front suspension as the avo shocks need a referb, engine bay needs a clean up.
Then need to decide if to sell her or do the turbo upgrade and get respray and keep.her
Re: Pinky II
Postby Rambo » Sat 04.04.2020, 15:41
Welcome back Monty :wink:
Re: Pinky II
Postby Steve A » Sat 04.04.2020, 19:08
Rambo wrote:Welcome back Monty :wink:
What he said, WTF have you been :poke:
Re: Pinky II
Postby Dave Eds » Sat 04.04.2020, 19:12
Ditto :-D
Just waiting for Dico now......
Re: Pinky II
Postby Monty » Sat 04.04.2020, 22:25
Thanks guys, good to be back on and I'm sure there's a lot to catch up on. Just need to get the thing started so I can start the work.
Ditto :-D
Re: Pinky II
Postby muley » Sun 05.04.2020, 06:07
Welcome back!!
If I was in your situation, I'd probably want to make sure the engine could turn over OK.
I'd remove all 4 plugs, pop 1/2 teaspoon of engine oil in each cylinder, jack up 1 wheel, put the car in gear and turn the wheel to get the engine moving ~ then try starting (after the plugs are back and you are in neutral)
BTW a seized clutch won't stop
engine turning unless it's in gear..
