I guess it’s a fine line between “if it ain’t broke, don’t fix it”, and preventive maintenance while you can. I’ll do a bit of planning a la Rambo over the weekend and take it from there.
Thanks again for the wise counsel; it’s much appreciated
Quite right Dave - I stand corrected!dapinky wrote:as far as getting the head skimmed goes, there is a tollerance for removal of material (16 thou),
Saltire wrote:Listen: if Pauline can plant her latest shrubs on my workbench, generously distributing potting compost around the toolbox as she goes, I reckon I’m entitled to roll my valves on her nice granite worktops![]()
very bad luck. Just as the good weather is upon usSimon_P wrote:Not wishing to state the obvious , but some valves will be open while the cams are still in place.
Simon_P wrote:There doesn't appear to have been any contact on the valve in the photo - Could you post a picture of the whole head?
Simon_P wrote:The exhaust manifold takes the whack when you ground the exhaust hence the cracks - did you spray it with water and let it dry to highlight the cracks?
dapinky wrote:However, my thoughts now are :-
If the head gasket has gone, coolant will be getting where it shouldn't - and if it has got into the combustion space, it may have gone up past the valve seats (whilst the engine is at rest, with valves open) - and then caused rust on the exposed valve stems
Rambo wrote:Had the engine been standing long after the HGF Jonathan ?
dapinky wrote: . . . when the head is stripped, it is an ideal time to whack it in the dishwasher to make sure all the crud is out of the passageways![]()
