Poly Bushes
Poly Bushes
Postby don6962 » Thu 18.06.2020, 10:18
Hi do Powerflex or any other manufacturer supply a poly bush kit to replace all the bushes on the Elan?
91 ELAN BRG
don6962
Re: Poly Bushes
Postby Fredjohn » Thu 18.06.2020, 10:33
don6962 wrote:Hi do Powerflex or any other manufacturer supply a poly bush kit to replace all the bushes on the Elan?
Don't know the maker, but SJs sell poly bushes for the Elan.
See here
Re: Poly Bushes
Postby dapinky » Thu 18.06.2020, 10:39
South West Lotus also do poly bushes.....
..... sometimes they are cheaper from SJ's, sometimes from SWL (but never much in it) - overall, a complete set will be the same price from either supplier.
(they are all made by the same supplier to both of these retailers)
Re: Poly Bushes
Postby don6962 » Thu 18.06.2020, 13:02
Cheers does anyone know the part numbers for a full set?
91 ELAN BRG
don6962
Re: Poly Bushes
Postby Fredjohn » Thu 18.06.2020, 13:19
don6962 wrote:Cheers does anyone know the part numbers for a full set?
I suspect there isn't such a number.
You'll have to either compile the various items on SJ's or SW Lotus website to create an order, or speak to either of them on the phone.
Re: Poly Bushes
Postby Saltire » Thu 18.06.2020, 19:07
I did mine eighteen months ago. There isn’t a “set” as such; you need to compile a list from DeRoure and/or the parts lists.
For what it’s worth, I would counsel against using poly bushes all round. When I researched the situation, some OEM bushes were no longer available and I had to have polyurethane. I was strongly advised by a number of Lotus cognoscenti not to use poly on the raft, because it works in a different way from what Lotus intended and changes the handling of the car.
In the end, I bought OEM where I could from either SJs or Kelvedon, including all the raft bushes, and polyurethane for the remainder.
Re: Poly Bushes
Postby rip » Thu 18.06.2020, 22:13
Saltire wrote: I was strongly advised by a number of Lotus cognoscenti not to use poly on the raft, because it works in a different way from what Lotus intended and changes the handling of the car.
That makes sense. The rafts are supposed to move a little & are a major design feature of the M100, not just another component. Lotus engineers will have used the correct size/material combination to provide the optimum movement.
Poly bushes will be less flexible, so the rafts won't move as much as they are designed to.
Re: Poly Bushes
Postby Rusty Wishbone » Fri 19.06.2020, 10:54
Saltire wrote: In the end, I bought OEM where I could from either SJs or Kelvedon, including all the raft bushes, and polyurethane for the remainder.
This is what I would do too. I take the view that, if polybushes are the best type of bushes to use, Lotus would have fitted them in the first place.
Rusty Wishbone
Re: Poly Bushes
Postby Simon_P » Fri 19.06.2020, 11:41
Saltire wrote:because it works in a different way from what Lotus intended and changes the handling of the car.
As do the wishbone bushes which are interleaved rubber (Metal/Rubber/Metal/Rubber/Metal) to change their properties, they use the resistance of the rubber whereas poly are designed to rotate.
A few years ago I investigated getting the bushes remade, I found a company that could do the job, but then found enough bushes to get the job done. Then again last year I needed another set and contacted the supplier, It got put on the backburner (car in pieces) until last weekend when I started work on the rear suspension and find myself in need again. So now I need 3 sets.
I have re-made the contact with the manufacturer and it would be useful to know if anyone else needs some so I have numbers when discussing the quote - expressions of interest here please viewtopic.php?f=85&t=28114
