if I have understood your description "fully extended" is jammed closed (as it extends it blocks the hole), which makes sense as it can't keep the revs down. Also it is a stepper motor so it isn't actually jammed.M100TURBOFR wrote:However, I think I've found the culprit. I think it must be the IAC as on taking it out I see it's jammed solid (spring portion fully extended and jammed open.
There are a number of things that could be wrong which are easily detected with elanscan.M100TURBOFR wrote:No I do not have Elanscan.
I wouldn't consider that particularly high revving or a long period of time, you might annoy the neighbours though.M100TURBOFR wrote:The problem is that I am frightened to let the engine rev so high for a long period of time until I could, for example, get the paperclip installed.
A good piece of advicetb10 wrote:Have you checked the temperature sensor?
Users browsing this forum: Bing [Bot] and 1 guest
