Window Upstop Bobbins & Tapping Plates
Postby CallMeLegend » Wed 19.08.2020, 22:21
Having nearly got the drivers window working properly, apart from a small judder mid stroke I've noticed I'm missing my upstop bobbins on the electric windows. Are they available anywhere please?
CallMeLegend
Re: Window Upstop Bobbins
Postby tb10 » Wed 19.08.2020, 22:26
Check in the bottom of the door as they do fall off and roll to one end or the other but which end of the door depends on how fast you accelerate or if you have Hi-spec or AP brakes I suppose! :lol:
tb10
Postby CallMeLegend » Wed 19.08.2020, 22:27
tb10 wrote:Check in the bottom of the door as they do fall off and roll to one end or the other but which end of the door depends on how fast you accelerate or if you have Hi-spec or AP brakes I suppose! :lol:
The mounts for the bobbins are missing too......
CallMeLegend
Postby tb10 » Wed 19.08.2020, 22:40
You've got superb brakes then! :clap:
Seriously, they may have been left out if the weather seals have been replaced as the glass is a bugger to get back in. Not sure if you can buy them anymore? I have one that needs to go back in so if someone can 3d print them I'll loan one for a batch to be printed.
tb10
Postby CallMeLegend » Wed 19.08.2020, 22:42
tb10 wrote:You've got superb brakes then! :clap:
3d printing......one of my areas of expertise. My 3d printed lock escutcheons are a thing to behold.
All I'll need to do then is sort the the threaded part that's bonded to the glass.
CallMeLegend
Postby tb10 » Wed 19.08.2020, 22:53
CallMeLegend wrote:All I'll need to do then is sort the the threaded part that's bonded to the glass.
If you have the metal backplate then all you are missing is the bobbin and the screw? The bobbin has a small dowel to locate it in the window?
tb10
Postby Brit-Car-Nut » Wed 19.08.2020, 23:16
Nothing should be bonded to the glass, not even the plastic washer.
Part # A100B0817F. Still in the Price Book at £10.54.
Sjs also has them at £9.72
The tapping plate is also still available from any Lotus dealer as is the plastic gasket.
Postby tb10 » Wed 19.08.2020, 23:21
Cheers Brit-Car-Nut!
tb10
Postby Brit-Car-Nut » Wed 19.08.2020, 23:35
Here are the pages from the service manual:
Elan-M100-Service-Manual.pdf
The upstop locking plates (what the bobin runs into) are
Part Number: E100B0319F
Description: Locking Plate Assy-Rear
Qty on Car: 1
Price (each): £27.08
Part Number: E100B0322F
Description: Front Locking Plate RH
Qty on Car: 1
Price (each): £18.68
Postby CallMeLegend » Thu 20.08.2020, 06:50
At those prices it's going to be cheaper to 3d print something. All I need is a drawing of the bobbin. A 3d printed tapping plate is very doable too I'm sure, the thread can be produced by bonding a nut in from the rear.
CallMeLegend
Postby Fredjohn » Thu 20.08.2020, 07:15
Given tb10's comment re lack of space, it may not be possible to use a nut bonded on.
Could you not use an alloy riv nut of appropriate size? eg M6 or M8?
Postby CallMeLegend » Thu 20.08.2020, 07:40
Fredjohn wrote:Given tb10's comment re lack of space, it may not be possible to use a nut bonded on.
How about female big heads then?
https://www.hall-fast.com/fasteners-sma ... -10-212397
Or alternatively since I may be 3d printing the bobbins a rivnut bonded into an aluminium plate to act as the tapping plate, I can then make the bobbin match it
CallMeLegend
Postby CallMeLegend » Thu 20.08.2020, 07:59
That's the problem, I don't appear to have any of it!! There's just holes in the glass
CallMeLegend
Postby dapinky » Thu 20.08.2020, 09:51
Personally, I would be looking at the female big-heads, as long as the diameter of the shank fits through the hole in the glass, the rest can be made to match.
Postby tb10 » Thu 20.08.2020, 10:03
CallMeLegend wrote:That's the problem, I don't appear to have any of it!! There's just holes in the glass
Ahhh, I thought you 'had' the threaded part. Good old English eh: "All I'll need to do then is source the the threaded part that should be bonded to the glass." :mrgreen:
Look on the bright side - at least you haven't also lost the two holes in the window :lol:
tb10
Postby CallMeLegend » Thu 20.08.2020, 10:17
.....yet
CallMeLegend
Postby CallMeLegend » Thu 20.08.2020, 10:33
This "tapping plate" may be perfect.
https://www.hall-fast.com/fasteners-sma ... 7?___SID=U
CallMeLegend
Postby dapinky » Thu 20.08.2020, 12:20
tb10 wrote:Ahhh, I thought you 'had' the threaded part. Good old English eh: "All I'll need to do then is source the the threaded part that should be bonded to the glass." :mrgreen:
Ahhhhh........
...... carefully-chosen words - the tools of the trade for a Lawyer 8)
Re: Window Upstop Bobbins & Tapping Plates
Postby Fredjohn » Thu 20.08.2020, 17:32
Great legal words John.
Except it SHOULDN'T be bonded to the glass. Just the bolt into the mounting plate to retain it.
I'll sue you for misleading info. Know a good lawyer? :-D
Postby Brit-Car-Nut » Thu 20.08.2020, 17:47
Isn't that what I said?
"Nothing should be bonded to the glass, not even the plastic washer."
Return to Interior
