dapinky wrote:... but the article was very old, American, and with no follow-up as to the results!
Hey! I resemble that remark
TorqueHorse wrote:Hey! I resemble that remark
dapinky wrote:...many things are written in a way that the 'others' don't always think in...
Tuga2112 wrote:davidcgriffiths wrote:When I reconnect the battery the motor for this side runs & I get a knocking sound for 7 seconds, the pod does not lift.
this is the kind of behaviour that we have seen happening when some of the "pills" are broken and no longer creating a good connection between the gearsdavidcgriffiths wrote:Once powered up the pods can be operated as normal using light switch, however the near side pod knocks for 7 seconds on lifting and lowering.
when some of the pills are damaged this is one of style of symtoms members have found in the past.davidcgriffiths wrote:If I disconnect the pod motor at the local plug and reconnect as expected nothing happens.
the local motor connection will not trigger a "reset", the "reset" is commanded by the lift module
we are all suggesting that you need to check and likely replace the "pills" because the symtpoms described are consistent with that type of issue from many other owners accounts.
I've uploaded to youtube a short video with intention to clarify a little further the refurb kit and motor operation
