dapinky wrote:Ah, that looks so much better when fitted to the correct sides!
Always said that Stevo "didnae ken his earse fae his elbae"
Rambo wrote:dapinky wrote:Ah, that looks so much better when fitted to the correct sides!
Rambo wrote:With such manky A and B post channels and seals I can't but help think that you will have hidden problems under the carpet ie cills/outriggers. I hope I'm wrong Mark
TorqueHorse wrote:
Looks like your A pillar drain plug has been filled in too (I discovered mine was when taking all that stuff off too). Verythat that would be the factory detail, but also
how two different series cars, in different markets would have gotten the same aftermarket treatment. I had an air compressor on the bottom of one of my drains and couldn't even get the slightest whiff past that rubber plug at the top. I ended up drilling them out with a small drill bit and then using a small pick and tweezers. I mean the whole thing is kind of wishful thinking based on how high up that drain hole is, that any water pooled in the recess at the top of the A pillar would go in the drain before spilling over one of the sides first...but then why go to all the trouble of putting the drain hose in, in the first place? Hope the new Jamie seal just blocks it all out for you anyway.
GeoffSmith wrote:Looking good.![]()
Do the pods raise with the LED unit?
CallMeLegend wrote:…light was against me.
