Drivers door locking and staying locked.
Postby alexherb » Sun 28.06.2020, 20:18
Evening,
Sorry if this topic has been covered already. I am new to this kind of forum.
I have nearly finished a restoration on an M100 Normally aspirated version. Been a pleasure tinkering with it and now lovely to drive it around whilst finishing the last few bits which need doing. I have hit a stumbling block which I cannot for the life of me resolve.
The central locking seems to work (as in it makes the correct noises!) but each time I lock the drivers door it stays locked and i need to do a Dukes of Hazzard to get out! The passenger door works fine. I cannot recall tinkering with the lock, but late one evening i may have....the mind fades! I have replaced both door waste seals https://www.youtube.com/watch?v=Xps5s0sbm3w and will be refitting windows properly (windows are in but one window needs a runner block) and re-fitting doors cards etc once the lock issue is resolved.
Does anyone have an idea what may be wrong with the central locking? I am normally quick good with auto electrics but this has well and truly stumped me...
Many thanks
Alex
alexherb
Re: Drivers door locking and staying locked.
Postby Rambo » Sun 28.06.2020, 20:32
Hello Alex - my 1st thoughts are the door microswitch. My 2nd thoughts ard ghat it might be connected to the alarm/immobiliser
Have you had a look at the electrical diagrams ? I believe you can download these via Britcarnut's (LEC member John) hosting facility
Postby GeoffSmith » Sun 28.06.2020, 22:12
Postby alexherb » Sun 28.06.2020, 22:44
Thank you Geoff and Rambo. Really helpful.
I did wonder if this was a door ajar switch issue or if i had done something stupid when taking the glass out.
Geoff that schematic is so useful. Thank you.
No i just need a nice hot day and peace and quiet to sit down and work it all out...and also need to figure out how to get the door open again!
alexherb
Postby GeoffSmith » Mon 29.06.2020, 09:26
No problem Alex. There is a lot of technical information captured on the WikiLEC.
Postby alexherb » Thu 29.10.2020, 12:16
Thank you there's only on f in Geof Smith and Rambo. It was the door microswitch - purchased whole new assembly and door now sorted. Nasty little job!
alexherb
Return to Doors and Windows
Users browsing this forum: AhrefsBot and 6 guests
