dapinky wrote:Joao,
Zinc plating comes in 2 flavours - electroplating, and galvanising.
Galvanising involves dipping the metalwork in various chemicals to clean it up, and then into a hot bath which gets the zinc to stick to the steel.
I would think that the 450C required for galvanising would have a detrimental affect on the bushes (as well as covering them in molten zinc!) - so to do it would require removal and later replacement of the bushes..... also, as the steel will be somewhat weakened/thinned from aging, it may well cause the wishbone to deform (but I've never tried it, so am just guessing)
Electroplating involves a much more scientific method of coating at 'normal' temperatures, but because of the size and shape of the wishbone, I don't know how even a coating it would provide due to the localised electric current.
Personally, I'd give them a good clean, then soak them in phosphoric acid to kill/convert any remaining rust (including the inside surfaces)...... then paint them with chassis paint (or even Zinc paint).
Rambo wrote:If you are going down the electroplating/galvanising route you will definitely be better off removing the bushes. But perhaps if you are future proofing things it might be better off replacing the bushes now anyway ??
Saltire wrote:Joao
Bushes are easy to get - at least compared to some things on the Lotus. When I did my suspension rebuild (F and R) two years ago, I got some from SJs, some from Kelsport. Many are available to OEM spec, but for some bushes, the only option is polyurethane. If you want to go 100% down the poly route, several of the regular suppliers (e.g. Powerflex) will do a set for the Elan.
)Rambo wrote:For anyone else who just wants to buy something off the shelf, Steven (Par) swears by this product https://www.landroverblogger.com/product/metalmorphosis
Rambo wrote:PS the very worst acid to work with was HF (hydrofluoric) If you didn't wash off a spillage immediately on contact with the skin it would get through and attack the bone beneath. Nasty stuff
with Simon_P. While it is possible to do home plating, it’s often hard to control the coverage on irregularly shaped parts, and you’re dealing (as we’ve discussed) with several sorts of corrosive chemicals, which won’t do the furnishings any good at all Return to Projects - Other (Minor)
