lamba failure
lamba failure
Postby kbee » Thu 13.05.2021, 19:11
I have had a problem with my car ticking over at 1200rpm and would not reset by service mode.At each gearchange the revs hung on . Timing was checked and corrected , every vacuum pipe from the plenum replaced or checked , vast quantities of wd sprayed to try and get a rise in rpm no effect , tps checked working perfectly . At this time I had no idea what to do . Then remembered a previous problem with a TVR . So disconnected Lamba , the tickover immediately dropped to just under 1000rpm and it stopped hanging on the throttle . Has anyone had this problem and where can I get a lamba It's a 1995 S2 Turbo
kbee
Re: lamba failure
Postby Fredjohn » Thu 13.05.2021, 19:31
Look in Wikilec under Oxygen Sensor.
Gives various alternative manufacturers and part numbers.
Re: lamba failure
Postby Saltire » Thu 13.05.2021, 19:34
I assume you mean this.
Plenty of information also in WikiLEC, (use the link at the top of the page).
Re: lamba failure
Postby Saltire » Thu 13.05.2021, 19:35
Fredjohn wrote:Look in Wikilec under Oxygen Sensor.
Sorry, John, simultaneous typing :D
Re: lamba failure
Postby Rambo » Fri 14.05.2021, 06:15
kbee wrote:I have had a problem with my car ticking over at 1200rpm and would not reset by service mode.At each gearchange the revs hung on . Timing was checked and corrected , every vacuum pipe from the plenum replaced or checked , vast quantities of wd sprayed to try and get a rise in rpm no effect
It's a drop in rpm you need, not a rise :shock:
The car will idle from cold at ~1200 rpm but when the engine is warm you need to adjust the tickover to ~950 rpm in service mode. It won't just reset itself in service mode. You need to adjust the tickover speed manually - see Wikilec. Also, check that the throttle cable is correctly adjusted
PS where on earth were you spraying vast quantities of WD40 and why :smt017
Re: lamba failure
Postby HJ2 » Fri 14.05.2021, 09:44
WD40 (or brake cleaner) On the vacuum lines Rambo.
If there is a leak it is sucked in and act as extra fuel, hence the expected rise in rpm.
Re: lamba failure
Postby kbee » Fri 14.05.2021, 17:38
I did adjust the tickover manually but on returning to normal mode the tickover rose again,If you spray WD on a vacuum leak it causes the revs to peak for a short time indicating the location of a leak.
kbee
Re: lamba failure
Postby Simon_P » Fri 14.05.2021, 20:33
It might on a car with carburettors, but with the ECU controlling the RPM to the target idle you are fighting a computer - it might work in service mode though.
