Hot starting problem
Postby Russh » Mon 10.05.2021, 19:49
The first start in the morning or even after weeks of no use is instant .in fact you hardly have to turn the key. But after that I have to turn it over for at least 10 seconds before it fires up,and then there is a petrol smell for a few second.
I've only owned the car a few months, when I brought it the previous owner told me he had had this problem for all his 7 years of ownership. As it was due a new cambelt I thought a good service would make it better .Well the cambelt turned into a new head gasket as well and still the first start is instant and subsequent starts are about 10 seconds .
Other than this annoying fault the car runs really nice.
Any suggestions please would be appreciated.
Russh
Re: Hot starting problem
Postby GeoffSmith » Mon 10.05.2021, 20:14
Is it an SE or S2?
Postby Dave Eds » Mon 10.05.2021, 20:25
Postby GeoffSmith » Mon 10.05.2021, 20:54
Well that's the easy diagnosis down the pan.
Postby HJ2 » Tue 11.05.2021, 05:27
Why if I may ask? :?:
Postby Rambo » Tue 11.05.2021, 06:12
HJ2 wrote:Why if I may ask? :?:
Because it's Geof (only one effin') Smith HJ. And he's an "awkit bugger" British humour too. We are top of the sarcasm league table. Unlike Newcastle. See, more sarcasm :wink:
Back to the OP. Please try searching for info before you ask (box top right and/or Wikilec, top left) It's all been covered before. The primary cause of no problems starting when cold but requires more cranking when hot is down to the vapourisation of petrol.
However it could be due to a faulty CTS or TPS. Or possibly a clogged fuel filter. In fact, there are quite a few other reasons but my money is on vapourisation. It is not uncommon with these cars but not everyone appears to get it. I had this problem with my 1st M100 (SE) but not my other 2 SE's
I've not heard of anyone having had this problem with an S2 so maybe Geof was on to something after all
Postby HJ2 » Tue 11.05.2021, 06:49
I did have the problem with my S2 (and there's a topic) and I am not being sarcastic :lol:
Postby Russh » Tue 11.05.2021, 08:50
Opps forgot to say it's a 1990 SE Turbo with 80k
And by the way. What is a CTS and a TPS .I put these letters in the search box and nothing came up
As you can guess I'm new to Lotus ownership and even newer to the forum :D
Russh
Re: Hot starting problemt
Postby Saltire » Tue 11.05.2021, 10:17
Russh wrote:Opps forgot to say it's a 1990 SE Turbo with 80k
    CTS = Coolant Temperature Sensor - tells the engine Electronic Control Unit (ECU) how hot the engine is
    TPS = Throttle Position Sensor - tells the ECU how far you have the accelerator pressed.
Between them (and with several other sensors) they help the ECU to know how rich the mixture should be, or in simple terms, how much fuel to push into the engine.
Postby GeoffSmith » Tue 11.05.2021, 12:07
If the CTS goes open circuit, the ECU overfuels when the engine is hot. If the engine runs long enough for the O2 sensor to warm up then the ECU goes closed loop, fuels correctly and it runs fine. This happened on another car and shorting the CTS wire allowed me to get the car started.
Postby HJ2 » Tue 11.05.2021, 12:17
I knew you had a good reason :D
Postby Russh » Tue 11.05.2021, 13:36
Thank you
Russh
Postby GeoffSmith » Tue 11.05.2021, 14:26
Take a look at the Wiki Russ.
Postby Russh » Mon 31.05.2021, 10:18
Just changed the fuel filter and CTS and one of the pins in the CTS was bent over and not making contact with the plug.
Just need to put a few miles on it to see if its any better .Fingers crossed
Russh
Postby GeoffSmith » Mon 31.05.2021, 14:29
Russh wrote:… one of the pins in the CTS was bent over and not making contact with the plug.
99.9% certain that was the cause of your problems. You'll probably find you use less fuel as well.
Postby Russh » Sun 20.06.2021, 15:34
Well after a few miles and starts with the new fuel filter and CTS. The instant cold starting has gone ,have to crank it over quite a bit before it starts and the hot starting is a little better but still need cranking for quite a while.
I know it will not be running so rich ,but was hoping for better
Where to now.Any suggestions
Russh
Postby Russh » Fri 13.08.2021, 20:23
I was hoping for some ideas.
Could I have a duff CTS
Russh
