Indicators acting up. Hazard switch?
Postby Paul Alexander » Tue 01.06.2021, 18:38
Hi everyone. been a while since i last posted, but hope people have been keeping safe as we now seem to be coming out of the covid situation.
My elan has failed its MOT, - horn stopped working and all indicators come on when i indicate left or right.
I can fix the horn because the 15A fuse has blown. However with the indicators:
1. i have fiddled with the hazard switch and now the hazards work correctly and the indicator light on the dash board does not come on (i believe this is the correct way).
2. the problem is when i indicate left or right, the light is on on the dashboard and the relevant lights flash on and off normally but the opposite side indicators also come on, however they are fainter and don't flash at the same rate as the normal side operation (they are a bit slower).
is this fault still to do with the hazard switch? or is the indicator relay duff? or is it something else?
any help is appreciated. cheers.
Paul Alexander
Re: Indicators acting up. Hazard switch?
Postby lancselanman » Tue 01.06.2021, 21:59
I'm having the same problem with my indicators and hazard switch too.
Happened a month after the MOT and I'm struggling to find a replacement.
I suspect the MOT station dismantled the switch to effect a temporary repair which has since failed again. The front of the switch has become detached.
Lancselanman
lancselanman
Postby Steve A » Tue 01.06.2021, 22:12
If you use the search function you'll find the answer
Postby Dave Eds » Tue 01.06.2021, 23:37
Lancselanman
Why?, when they could just fail it and charge to repair and retest it..... :roll:
Postby Rambo » Wed 02.06.2021, 07:57
Dave Eds wrote:
Lancselanman
Exactly. An MOT station worth it's salt won't do temporary repairs like that just to fudge an MOT. Those days are long gone :?
Postby Paul Alexander » Wed 02.06.2021, 19:46
well, i've fitted a new 15a fuse for the horn tonight, and thehorn is ok, but bizzarley the indicators and the hazard switch all function correctly now. tested everything three times, and all ok. wonder if the blown fuse was causing some sort of current leak or drain to the indicators / hazard circuit?
oh well, will check again tomorrow and re-book mot.
Paul Alexander
Postby Paul Alexander » Wed 09.06.2021, 16:47
Hooray. She passed the MOT.
after looking at the circuit diagrams again, the only common point i could see was the indicators / hazard switch, and horn are also connected to the alarm. i found that the battery in my alarm keyfob was low (almost flat), and i am wondering if this affected the alarm causing the horn fuse to blow.
fitted a new battery and all is ok.
Summer, here we come.
Paul Alexander
