Anti chip film
Anti chip film
Postby Elanthrapist » Tue 15.06.2021, 19:03
Hello all,
I am just about to have the sill areas sprayed due to stone chips. I have aquired a set of 4 anti chip film protectors. Does anyone have these fitted and if so can you supply pictures of them front and back. The difficulty I have is what goes where, it's not obvious and I want it to look right and also protect the right areas.
With many thanks, best regards, George.
1968 Elan S4 dhc (Now sold).
1973 Elan Plus 2 S130/5 [Lagoon Blue].
1994 Elan M100 S2[Medina Green].
Elanthrapist
Re: Anti chip film
Postby scotlan » Tue 15.06.2021, 21:28
Mine has 4 chip protectors, the large one above the sill line and the narrow one directly below. None at the front
hope this helps
scotlan
Re: Anti chip film
Postby johnj » Wed 16.06.2021, 10:46
My car had film strips on it when I bought it but dirt had got behind them making them look nasty. I got them off ok but trying to put them on was a nightmare. I wasted one and gave up. Is there a technique to put them on smoothly?
johnj
Re: Anti chip film
Postby david924s » Wed 16.06.2021, 11:49
I don't have them on the Elan, but when I replaced the ones on my 944 I sprayed the area on the car where they were to go with soapy water (couple of drops in a spray bottle) then when you fit the film it can move about on the water until you get it right then use a squeegee to push out the water underneath. Bit like putting transfers onto models when you were a kid!
david924s
Re: Anti chip film
Postby johnj » Wed 16.06.2021, 21:06
A long time since I was a kid :( but will give your technique a try. Thank you
johnj
Re: Anti chip film
Postby exeterjeep » Sat 30.04.2022, 20:37
I have recently done all 4 on my S2, took a while to get off using the heat gun on low and some sticky stuff remover, the slightly soapy way was fine.
Has anyone fitted a similar PPF layer to protect the area where the soft top sits on the rear deck. Managed to get off most of the marks and a good polish helped.
exeterjeep
Re: Anti chip film
Postby Rambo » Sun 01.05.2022, 20:44
I believe Geof (only one effin') Smith did a group buy a few years ago. He may have one or two left?
PS I could do with a couple too Geof. In lieu of a couple of Beadnell's finest ;-)
Re: Anti chip film
Postby dapinky » Mon 02.05.2022, 10:24
Rambo wrote:PS I could do with a couple too Geof. In lieu of a couple of Beadnell's finest ;-)
I know of a tall ginger bloke with a respray who would like some as well.......
