EM One Hundred wrote:2.Radiator cap (the one on the coolant tank at the firewall) is snug but not really tight. If I tighten it any more it slips a thread and I start all over tightening again.
EM One Hundred wrote:…Also, I am not a strong mechanic, I know just enough to be dangerous and also my limits so I know when to take it to my mechanic!
EM One Hundred wrote:Mileage is 56,800 Why is that a concern?
EM One Hundred wrote:Esprit 888 You are right...something is very wrong!
I filled the reservoir to the midpoint leaving the upper half for expansion as I was told by you (even though I knew that already) then screwed the cap on very tightly. It worked at first as it was supposed to but under real load it went kerblammo! I am as surprised as you are that it happened. I am not completely incompetent and you are not here so please believe what I am reporting.
Is there any other way that much pressure could build up in the cooling system?
