Simon_P wrote:No. Not as a drop in replacement.
What is the logic pump on when what happens etc?
GeoffSmith wrote:The socket as it stands is missing both an earth and a switched ignition connection.
Simon_P wrote:What is the logic pump on when what happens etc?
Simon_P wrote:Yes, that's the logic for the pump but you've forgotten the logic for the fans, so you have no supply or earth when you want the fan to run on - That I believe is Geoff's observation.
What is your logic? What do you want to happen under what circumstances?
with Simon_P: why would you want to?Simon_P wrote:I understand how the existing circuit works (I think).
I don't understand what you are trying to achieve - I can't think of another way of asking so I'll try again. What is your logic? What do you want to happen under what circumstances?
GeoffSmith wrote:If you want the fans/pump to run continuously during the smog test then just short out the a/c pressure switch connector.
or fit a bypass switch. Then you could run the fans or pump whenever it took your fancy.tigerdog wrote:GeoffSmith wrote:If you want the fans/pump to run continuously during the smog test then just short out the a/c pressure switch connector.
Fekking brilliant! I was going to muck about with a jumper at the relay.
Simon_P wrote: or fit a bypass switch.
Simon_P wrote:or fit a bypass switch. Then you could run the fans or pump whenever it took your fancy.tigerdog wrote:GeoffSmith wrote:If you want the fans/pump to run continuously during the smog test then just short out the a/c pressure switch connector.
