by lotusles » Sun 29.08.2021, 17:04
Anybody else had constant coolant leaks from new silicone hoses?
Clips seem to need constant tightening and yet another puddle on the garage floor.
lotusles
by muley » Sun 29.08.2021, 22:05
In a word ~ yes.
Edited to add - not really constant. Just one or two to be nipped up a little
by Simon_P » Sun 29.08.2021, 23:16
Could be "compression stress relaxation".
When you squish rubber with a jubilee clip done up tight -over time the rubber relaxes and the jubilee clip becomes "loose".
by Rambo » Mon 30.08.2021, 06:52
Youre better with those "spring" type clips that self tighten (no idea of the technical name but I'm sure someone will tell me
- Don't push me
by Fredjohn » Mon 30.08.2021, 09:14
In a word.....no leaks after 4/5yrs.
Both Jonathon (saltire) and I used original jubilee clips from Samco.
See your thread 'new car delivered'.
by Rambo » Mon 30.08.2021, 09:24
I too used a set of the new Jubilee clips with the Samco hoses and have now done this twice. On both occasions there was a slight weep on one joint but I found it best to go round and nip them all up
Result = no leaks
- Don't push me
by Simon_P » Mon 30.08.2021, 17:14
Rambo wrote:Youre better with those "spring" type clips that self tighten (no idea of the technical name but I'm sure someone will tell me
Spring hose camps, but they're only practical for smaller sizes
Jubilee clips have the advantage that no special tools are required. The the variability is probably due to the user, one person's idea of tight enough being different to another.
Return to Heating and Cooling
