peter canepa wrote:My mechanic is suggesting something I have never seen posted about the brakes. He claims there is not enough boost. The vacuum volume in the booster is not enough. When you first step on the brakes, they feel great but as you continue, there is less and less power. He set up a test, a scuba tank and a hose to give the booster more volume. He claims it improved and we are now adding a permanent small tank mounted under the hood.
Anyone ever tried this? Stay tuned I pick up the car tomorrow.
Peter
peter canepa wrote:Sorry not to finish this thread. The results are fantastic! Just to review, after a test drive the mechanic, seemed to believe that there was not enough vacuum pressure. He noticed when you hit the peddle it would start firm and as you brake it would get softer. He added a beer can size reservoir to the system, thus increasing the tank. He tucked above the wheel well, drivers side, behind the plastics fender guard, ran a hose up to the brake pump added a T. Its really amazing and its super simple.
Peter
lotusflasherman wrote:peter canepa wrote:My mechanic is suggesting something I have never seen posted about the brakes. He claims there is not enough boost. The vacuum volume in the booster is not enough. When you first step on the brakes, they feel great but as you continue, there is less and less power. He set up a test, a scuba tank and a hose to give the booster more volume. He claims it improved and we are now adding a permanent small tank mounted under the hood.
Peter
Ridiculous ! Suggest you check the servo non-return valve and servo diaphragm and find a new mechanic. Nobody else has done it because nobody else needs it. When braking the throttle is closed, the brakes are slowing the car and the engine - which produces maximum vacuum in the plenum chamber which in turn opens the servo non-return valve and continues to feed 'vacuum' to the servo ... an extra tank is superfluous!
This may be useful .. brake-servo-fault-finding-guide/
19peace84 wrote:Hi sorry to jump on this old thread, I've just got a m100 and the brakes are awful, is there anywhere with these master cylinders in stock?
Jamie N wrote:I have front and rear modern upgrades, 2 full sets available, less than half the price of any other upgrades with just as good performance, especially in terms of the handbrake.
Sure there will be a few owners here that can testify. No modifications just bolt them on.
