dapinky wrote:Are you sure you need some new pads?
I only ask because when I changed my tank, some of the pads remained stuck to the bodyshell and not to the tank, so I thought I was 4 missing when I wasn't.
dapinky wrote:Good luck with trying to line up the bolts from the hood stowage area and getting them lined up with the nuts on the metal straps - it is a 2-man job, and even then it isn't always easy - I used some much-longer bolts and found it a little bit easier, but still not easy (until the time it "just works" by lining up perfectly and getting started.)
dapinky wrote:and I still don't know if it's easier to fit the rubber grommets round the filler neck from the inside or the outside - but I fitted them at the end of the job, which was fun!!!! (it was made harder by the roll hoops, so without them it would be a lot easier, I think).
